Facing Problem in generating more i/o's by using AVR
Sat Oct 25 2014, 12:44 am
Assembly Language Code:
.INCLUDE "M16DEF.INC"
LDI R20,HIGH (RAMEND)
OUT SPH,R20
LDI R20,LOW (RAMEND)
OUT SPL,R20;
LDI R16, 0XFF ;
OUT DDRC, R16 ; TO SET PROTC AS OUTPUT
CBI PORTC, 0 ; TO CLEAR STB PIN WHICH IS CONNECTED TO PROTC.0
LDI R17, 0x81 ; OUR DATA
CLC ; TO CLEAR CARRY REGISTER
LDI R18,8 ; WE HAVE TO RUN LOOP FOR 8 CYCLES THAT IS Y WE HAVE KEPT 8
AGAIN:
ROL R17 ; FOR ROTATING OUR DATA
BRCS ONE ; OF CARRY IS HIGH THEN GO TO ONE
CBI PINC,1 ; OF CARRY IS 0 THEN SET DATA PIN TO 0 MANUALLY
JMP NEXT ;
ONE:
SBI pinc,1 ;
NEXT:
SBI PINC,2 ;
CALL DELAY ;
CBI PINC,2 ;
CALL DELAY ;
DEC R18 ;
BRNE AGAIN ;
SBI PINC,0 ;IN THE END WE HAVE TO SET HIGH THE STROBE PIN
HERE:
JMP HERE ;
DELAY:
LDI R22, 29 ;
LOOP:
NOP ;
DEC R22 ;
BRNE LOOP ;
RET
OUT SPH,R20
OUT SPL,R20;
LDI R16, 0XFF ;
AGAIN:
JMP NEXT ;
ONE:
SBI pinc,1 ;
NEXT:
SBI PINC,2 ;
CALL DELAY ;
CBI PINC,2 ;
CALL DELAY ;
DEC R18 ;
BRNE AGAIN ;
HERE:
JMP HERE ;
DELAY:
LDI R22, 29 ;
LOOP:
NOP ;
DEC R22 ;
BRNE LOOP ;
RET
Sun Oct 26 2014, 06:08 pm
Hi Friends,
I made the strobe pin high before sending the data. After that the leds i want to open, they didn't hold. I am using Proteus to simulate it. As i start the simulation, the leds start on one by one, but that led which i want to hold it, that couldn't hold and it goes off....
Proteus diagram is attached....
Please help me out.
Thanks
Cheers...
Please help me out.
Thanks
Cheers...
[ Edited Sun Oct 26 2014, 06:11 pm ]
Assembly Language code is here:::::.......... I made strobe high before sending the data
OUT SPH,R20
OUT SPL,R20;
LDI R16, 0XFF ;
SBI PORTC, 0 ; TO CLEAR STB PIN WHICH IS CONNECTED TO PROTC.0
START:
AGAIN:
JMP NEXT ;
ONE:
SBI pinc,1 ;
NEXT:
SBI PINC,2 ;
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY ;
CBI PINC,2
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY ;
CALL DELAY ;
DEC R18 ;
BRNE AGAIN ;
CBI PINC,0 ;IN THE END WE HAVE TO SET HIGH THE STROBE PIN
JMP START ;
DELAY:
LDI R22, 29 ;
LOOP:
NOP ;
DEC R22 ;
BRNE LOOP ;
RET
OUT SPH,R20
OUT SPL,R20;
LDI R16, 0XFF ;
START:
AGAIN:
JMP NEXT ;
ONE:
SBI pinc,1 ;
NEXT:
SBI PINC,2 ;
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY ;
CBI PINC,2
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY
CALL DELAY ;
CALL DELAY ;
DEC R18 ;
BRNE AGAIN ;
JMP START ;
DELAY:
LDI R22, 29 ;
LOOP:
NOP ;
DEC R22 ;
BRNE LOOP ;
RET
Mon Oct 27 2014, 12:15 am
Proteus file is heremsideal
Convert your Proteus file(s) to a Zip file before attaching.
Include the .hex file as well, so we don't need to
assemble/compile your code.
[ Edited Mon Oct 27 2014, 12:19 am ]
Mon Oct 27 2014, 12:46 am
sorry guys, i can't able to put the proteus file
The zip file is attached here
In this both circuit diagram and hex are attached
Mon Oct 27 2014, 03:54 am
sorry guys, i can't able to put the proteus filemsideal
Only a certain file types can be attached.
"Allowed file types: | .zip | .gz | .jpg | .png | .gif | .rar | .pdf |"
The hex file you uploaded does not seem to be for the code in
your post 14.
For a test, what do you want to happen ?
Mon Oct 27 2014, 11:15 pm
i want to extend my i/o's by writing this code. i have to attach five CD4094 to get 40 outputs. At the moment i'm using only one CD4094 to check how it works...... but problem is... the leds that i want to be open. They don't on and other leds on... what's the problem??? I also made the hardware and check on it as well. but problem remains same
Tue Oct 28 2014, 03:59 am
Your error seems to be the use of PINC, which is for
reading input, not setting output.
This code should be a good starting point.
I posted the wrong one earlier.
It writes the data in variable "pattern" to the 8 LEDs, then stops.
[ Edited Tue Oct 28 2014, 04:46 am ]
