Discussion in "Project Doubts" started by    sankalp_s    Nov 30, 2014.
Tue Feb 24 2015, 12:33 am
#41
You need to use tables.
That will make designing and reversing much easier.
Here is an example
Sir in this code, led blow constantly and nothing else.
any other idea which can merge in my code easily.
can you expand this example for 2 or more pattern with 12 line output?
[ Edited Tue Feb 24 2015, 12:48 pm ]
Tue Feb 24 2015, 05:19 am
#42
sankalp_s
That code is just the example, not the complete program.
I have attached a full program.
sankalp_s
There is no better way.
You can't do any more without dumping your existing code and
switching to tables.
That might be painful, but better done sooner than later.
sankalp_s
The attached code is for up to 16 LEDs.
Just point the DTPR to a new table to get a different pattern.
You have to use loops and calls to do the work,
You have to automate the process.
No more long sequences clearing single LEDs.
FYI...- when a LED glows it is good,when it blows it is bad
[ Edited Tue Feb 24 2015, 12:46 pm ]
Wed Feb 25 2015, 12:42 am
#43
[ Edited Wed Feb 25 2015, 12:53 am ]
Wed Feb 25 2015, 12:46 am
#44
Wed Feb 25 2015, 12:48 am
#45
Thank u dear PHIL sir it was very help full to learn...
sir, i've attached a jpg file where some definition are shown, whether can we do something like that for reverse, repetition of sequence & brightness of led as defined in that program.
actually i was talking about this type of code for mirror action.
[ Edited Wed Feb 25 2015, 12:50 am ]
Wed Feb 25 2015, 10:26 am
#46
brightness control is going to be tough job as you will need a varying PWM for atleast three LEDs which is not going to be easy to maintain. You can take reference from PWM tutorial for generating PWM, keeping different duty cycle will give you different brightness for LEDs.
 sankalp_s like this.
Thu Feb 26 2015, 06:28 am
#47
We seem to be moving away from the original project.
I don't think varying light levels will show up well for simple LEDs.
What are you trying to make ?
Fri Feb 27 2015, 02:57 am
#48
sir i want to make definition for mirror effect & repetition of design like shown on above picture.
is it possible with 8051?
brightness control is not required for this project.
thank you sirs.
[ Edited Fri Feb 27 2015, 02:59 am ]
Sat Dec 19 2015, 12:38 am
#49
Hello phil sir,
I am facing a problem in this code,
Problem is in chaser pattern when four led get off(as per code instruction) at same time, same leds blink with very low light.as per instructions lesds should not be blinked.
what will be issue?
can you help me sir?
here is code.
Mon Dec 21 2015, 07:50 am
#50
Hi..
Where have you been for the last 9 months ?
If you post a Proteus simulation I might be able to find the fault,
but I can't do it from just your code.
Sorry..
