Generation of Triangular wave using MCB2300
Fri Apr 17 2015, 11:00 am
In simulation everything went good but I am not able to get output on CRO by using the board.mayank058
You said the output was too low, was that in a simulation
or on the scope ?
Have you got a voltage on VREF ?
Where are you connecting your scope to ?
Can you get an output from the speaker ?
Fri Apr 17 2015, 04:33 pm
The output was low in the scope and I am using MCB2300 which works on 3.3V. So I am using that 3.3V as a Vref. and I am connecting the scope to the board.
Fri Apr 17 2015, 06:19 pm
can you post screenshot or a picture of CRO output? did you check if attenuation of probes is set correctly as per CRO?
