how to use DAC in LPC2378
Thu May 21 2015, 10:16 am
dear sir
there is nothing to zip.I just want to know, how to use DAC in LPC2378 or what kind of things I can do with this. Is it possible to convert a pulse wave into sine wave using this DAC.
Sun May 24 2015, 03:22 am
Does the speaker work?.
'Exactly' where on the board are you measuring ?.
Sir I want to measure the analog signal on CRO.mayank058
I know you want to measure the analog signal.
I asked where... what pin are you connecting the scope probe to?,
Also, does the onboard speaker work?.
Mon May 25 2015, 10:27 am
Dear sir,
I am taking output from PIN-8 (P0.26),,,,AOUT pin on the board..and the onboard speaker is also working good..,,
Mon May 25 2015, 11:46 pm
We need to do some simple tests.
Get the speaker to make a sound, continuous if possible.
Check Pin8 with your scope.. do you see a sine or square wave ?
Test jumper 3.. do you see a signal there, while the sound is playing ?
After doing that, try this code.
Do you get any compilation errors ?
//add device include files int main() { int bits; bits=PINSEL1 & 0xffcfffff; //preserve current settings for other pins bits |=0x00200000; //set P0.26 as AOUT PINSEL1 = bits; bits=PINMODE1 & 0xffcfffff; //preserve current settings for other pins bits |=0x00200000; //set P0.26 as no pullup or pulldown PINMODE1 = bits; while(1) //generate squarewave output { DACR =0; delay(); DACR =0x0000ffc0; delay(); } } //end main void delay(void) { int k; for(k = 1;k<= 10000;k++); }
[ Edited Wed May 27 2015, 03:15 am ]
Fri Jun 26 2015, 03:30 pm
dear Sir,
This program is working on the board.After downloading of this program, board shows a continuous pulse wave from the AOUT pin on the CRO and a beep sound from speaker.Now what to do. How can I vary the value of AOUT.
Sat Jul 04 2015, 11:44 am
You need to vary the digital value in DACR register to change the AOUT signal level.
