Discussion in "Project Help" started by    sachinmm    Apr 12, 2016.
Wed Apr 13 2016, 03:49 pm
i have to store all these 498 bytes data to array of below starting from array index position of [8] to [498]
unsigned char hex[508]={
0x5A,0xA5,0x0B,0x01,0xF4,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
Wed Apr 13 2016, 10:08 pm
One way...
create an index into your array.
int arrayIndex=8; //fill array from 9th byte
Use Karan123's method to open the file and read a char at a time from the file.
-------loop-----
Load to a small buffer until you get the separating comma, terminate the string
with a null byte.. 0
eg you have 0x12 in the buffer.
Use the strol() function to convert the string to an integer called "value".
store in the array called hex.
hex[arrayIndex]= (unsigned char) value; //caste the integer as a unsigned char
arrayIndex+=1; //next
---loop until all done.---
close file
Thread locked as OP has a similar thread running.
[ Edited Thu Apr 28 2016, 06:48 am ]
Astorne
Tue Apr 16 2024, 08:52 pm
Williamjaf
Tue Apr 16 2024, 12:25 pm
best_yyPa
Tue Apr 16 2024, 09:42 am
ErnestoExpop
Tue Apr 16 2024, 02:57 am
Jamesclepe
Mon Apr 15 2024, 11:10 am
Aliciaelora
Mon Apr 15 2024, 07:59 am
btaletvpcu
Mon Apr 15 2024, 04:36 am
UbvpwcTib
Mon Apr 15 2024, 03:13 am
