Forum Icons gone after installing furl
Discussion in "E107 FURL Support" started by FatFreddiesCat Apr 21, 2007.
Wed May 09 2007, 09:36 AM
i don't understand, if you please explain more or by steps what and which files to edit ?
thanks
thanks
[ Edited Wed May 09 2007, 09:37 AM ]
Wed May 09 2007, 12:36 PM
simply install FURL and set the rewrite base to /portal after that, your links will be yoursite.com/portal/index.html etc. make sure that the line
RewriteBase /porta is uncommented (if its commented the remove the '#' from the starting of line)
Wed May 09 2007, 01:19 PM
ok, that i was already did and every thing is working fine except that the forums images don't show up on the all forums pages : http://eglearn.com/portal/forum.html
the first lines of .htaccess :
RewriteEngine On
RewriteRule home.html news.php
RewriteRule index.html news.php
RewriteRule index.htm news.php
RewriteRule default.html news.php
RewriteRule default.htm news.php
RewriteRule index.php news.php
RewriteBase /portal
RewriteRule themes.html$ themes.php
RewriteRule themes([0-9]*)\.html(.*) themes.php?start=$1
RewriteRule themes-([0-9]*)\.html(.*) news.php?themepreview.$1
#RewriteRule download/(.+)/$ createzip/download.php?theme=$1
RewriteEngine On
RewriteBase /portal
Wed May 09 2007, 06:57 PM
i dont know whether its the problem in the theme you are getting this result. coz.. the thing is. even thought you are going to link http://eglearn.com/portal/forum.html
its taking images from http://eglearn.com/IMAGE_LINK
its taking from root. don't know the problem.
The person who started this topic, his problem is solved i think. So might be a theme issue. not sure.
what i can say is.. if you really want to use FURL then move your e107 in root directory.. or for testing try a different theme.
deebocean like this.
Thu May 10 2007, 10:58 AM
ok i think it's not the theme i tried another one and if i use the link http://eglearn.com/portal/e107_forum.html instead of http://eglearn.com/portal/forum.html it shows the images so i think i will go to the other option and get my e107 to the root
thanks for your caring to answer it was so helpful to me
Thu May 10 2007, 12:33 PM
you're welcome
i think its always good to have e107 in root. no redirects etc. if anymore issues please let me know.
