Nadi Pulse Measurement
Discussion in "New Ideas regarding projects" started by Amit Kumar Das Aug 26, 2012.
Sun Aug 26 2012, 07:21 am
Hello Readers..Can you tell me how can I sense the nadi pulse ? I have used vibration sensors but its not that much accurate. Is there any other method of measuring it ? I want 99.9% accuracy. Let me tell you that it's not for any business. It's for the welfare of the people and the application is w.r.t Ayurveda and not Allopathy medicine. Thanks in advance.
Sun Aug 26 2012, 11:10 am
@ Amit Kumar Das
normally accelerometer is used for sensing vibration of a specific thrust
Mon Aug 27 2012, 11:02 am
I am not sure about the accuracy level but I am confident this is much better:
http://www.analog.com/en/mems-sensors/mems-accelerometers/adis16227/products/product.html
Fri Aug 31 2012, 06:49 pm
Thanks Ajay for referring the sensor, I will try to acquire and test it, but want to share the MIR (Micro Power Impulse Radar) Sensor which can sense from a distance and the readings are extremely accurate. Visit at https://www.llnl.gov/str/pdfs/01_96.2.pdf
Tags MIR sensorMicro Power Impulse Radar sensor
