Discussion in "Embedded GSM Development" started by    07arunsharma    Feb 6, 2013.
Fri Feb 08 2013, 02:15 pm
ok.. I think you first need to understand the dormant state of modem. In dormancy GPRS connection stays alive but its not kind of active which means there is no actual data being transmitted or received at that time. So when you come out of dormancy mode your IP stays active (not changed unlike new GPRS connection) and you can resume data transfer again.
But not every GSM modem performs proper dormancy.. you will see your GSM device will show GPRS is on but you wont be able to send/recevie anything. Thats what the problem is. Dormant mode get active when you do not use GSM modem for a long time. usually its more than 15 minutes.. So if your modem is not communicating more than 15 or 20 mins then modem goes dormant.
Tags gsm dormantgprs modem dormancy
autogCar
Sat May 11 2024, 03:38 am
Dulcehet
Fri May 10 2024, 04:22 pm
ElvasKl
Fri May 10 2024, 04:54 am
RonaldNak
Thu May 09 2024, 07:45 pm
Jamescon
Thu May 09 2024, 12:52 pm
RobertSkats
Thu May 09 2024, 10:23 am
hvCar
Thu May 09 2024, 05:53 am
DJGlido
Wed May 08 2024, 09:28 pm
