Need recommendation for ARM9 based development boards!
Mon Jul 14 2008, 04:54 pm
Hi all, I am a student in a college, for an experimental project we shall need an ARM9 based development kit, with the SDRAM of at least 64M, ethernet, audio and LCD connection. I have been looking around for a long time and found nothing exactly meets my requirement. Since you guys have much more experiences in this area than me, would you plz recommend one to me? thanks a lot! -
Mon Jul 14 2008, 06:40 pm
The low cost and efficient ARM9 development which i came across is EP9302 based development board
the features of the board are as follows
Hardware:
· ARM9 processor (EP9302) @ upto 200 MHz
· On-board 8 MB Flash standard, optionally 16 MB.
· 32 MB SDRAM standard, optionally 64 MB.
· 2 UARTs with option for RS232 / RS422 / RS485 / 3.3V TTL (user selectable).
· RJ45 Ethernet LAN interface.
· Unique MAC ID is assigned to each board.
· 2 USB Host interface ports (can connect pen-drive, digicam, printer and many other peripherals…)
· 1 USB device interface port (can connect to PC)
· PC/104 connector (can connect to almost any PC/104 compatible I/O card)
· 5 channel ADC. As per official EP9302 documentation, it has 12 bit resolution. But we (and many other developers) have observed that it really gives 16 bit resolution.
· Upto 23 GPIO (3.3 Volts TTL)
· SD-Card interface
· RTC with battery-backup.
· Standard 20 pin JTAG interface
· Wall type power supply included.
· One serial cable and one USB cable included.
Software:
· Runs embedded Linux.
· Users may write stand-alone or Linux based applications to run on this board.
· CD contains sample programs.
· Enough memory to run other OSs like WinCE.
SBC9302 with 8 MB Flash and 32 MB RAM
13,500/-
210 EURO
SBC9302 with 16 MB Flash and 64 MB RAM
15,500/-
240EURO
Hardware:
· SD-Card interface
Software:
13,500/-
210 EURO
15,500/-
240EURO
[ Edited Mon Jul 14 2008, 06:42 pm ]
Wed Jul 16 2008, 07:39 am
Well~ it does seem like an advertisement, maybe I emphasized too much on the site, because I really think they are nice, both the board and the site, and I was just trying to share good stuffs to everyone. Of course you may regard it as an advertisement, it is your freedom to believe it or not.
Thu Jul 17 2008, 01:38 pm
Yes he has posted it on several forums
http://www.embeddedautomation.com/forum/showthread.php?p=4306
http://www.theiet.org/forums/forum/messageview.cfm?forumid=1&catid=222&threadid=25540
http://dobbscodetalk.com/index.php?option=com_fireboard&Itemid=31&func=view&catid=9&id=171
http://forums.bit-tech.net/showthread.php?p=1778091
http://electro-music.com/forum/topic-27719.html
http://qemu-forum.ipi.fi/viewtopic.php?f=20&p=13540
more & more, Please dont try this way. Try to be active in the forums and put your link as signature.
[ Edited Thu Jul 17 2008, 01:39 pm ]
Thu Jul 17 2008, 08:55 pm
what to do with this post then? block it?
Well good thing is you all realized it as advertising. I knew it but thought maybe..
Decide what to do
Decide what to do
Fri Jul 25 2008, 06:52 pm
I think without permission from the administrator ,you should not do fake advertisements according to me shuch members IP should be blocked so it will be a lesson for others;
