Discussion in "AVR Discussion Forum" started by    rahuljin    Jul 29, 2008.
Tue Jul 29 2008, 09:38 pm
since my lcd project is not working, i am starting to work on a new project and also try to work on lcd side by side.
i have the following material ----
1. ir leds
2. lrds
3. high intensity leds
4. lm324n comparator(14 pin DIP)
5. atmega32 with ADC
i want to make a line follower using atmega32. can anyone provide me a circuit for it. thanks.
[ Edited Wed Jul 30 2008, 09:42 pm ]
Wed Jul 30 2008, 08:20 pm
I am really thinking why your LCD program is not working, its really wired. Can you try the sample code given in LCD tutorial section? for AVR? just to check if the LCD is ok or not.
Regarding this line follower there are number of ways to make this project, as you are choosing simple switching IR signals, some use ADC etc.
I think you willl get a reference project online on that "Build your own microcontroller project" website.
Wed Jul 30 2008, 09:48 pm
i have checked. you may remember that i did the same project with 89s52. when i used that code, the lcd worked correctly.
sir, it is my first project in which some sensors will be used.
now i want to use a lm324n instead of ADC. can u provide a link or tutorial for it ??
one more thing --- i heard that signal from ir led can only be recieved by ir transistor. is there any other way ?? this is better ??
Wed Jul 30 2008, 09:58 pm
Thu Jul 31 2008, 10:57 pm
for receiving IR signal, i purchased some VS0038 ir receivers. but i didnot find any datasheet for it to use in the circuit. so please help me.
[ Edited Thu Jul 31 2008, 10:58 pm ]
Fri Aug 01 2008, 09:07 pm
they are same as TSOP1738, read that datasheet.
Sat Aug 02 2008, 01:34 am
i try to test so i made a simple circuit to verify that if output is obtained or not.
i tried to measure the voltage between output and ground but nothing.
then i tried to move the ir led near to receiver, but still nothing.
any help.
Sat Aug 02 2008, 10:04 pm
rahuljin,
reverse the IR led connections.
it is reverse biased as per ur diagram.
Sat Aug 02 2008, 10:13 pm
sorry, i draw it wrong. i wanted to correct it but the site was not opening.
so the corrected circuit---
but it is not working.
Mon Aug 04 2008, 09:04 am
If the output's not high without the IR led,probably the ir sensor's gone kaput.
Better get the TSOP 1738 available easily,instead of these no-name Chinese lookalikes.
MichaelGot
Tue May 14 2024, 04:08 pm
FrankTrelm
Tue May 14 2024, 10:39 am
BillyTum
Tue May 14 2024, 09:08 am
Loganbag
Tue May 14 2024, 04:05 am
MichaelMog
Tue May 14 2024, 03:58 am
ThomasGaxaW
Mon May 13 2024, 05:33 pm
RobertInfup
Mon May 13 2024, 04:28 pm
Joshuatem
Mon May 13 2024, 08:30 am
