Discussion in "AVR Discussion Forum" started by    rahuljin    Jul 29, 2008.
Tue Aug 05 2008, 11:19 pm
now i get two TSOP 1738 which are costly than chinese ones.
i use a ir receiver and ir led and gave then 3.3v supply. i placed them very near each other(0.5cm aprt) and an output of 0.3v is obtained. but after removing the led, i get the same result.
than i changed the led, but same result.
after that i changed the ir recevier, but this time also the same result.
now what to do.... :mad
Wed Aug 06 2008, 02:29 am
please go through this link it may also help you
http://onlinetps.com/raghu/
Thu Aug 07 2008, 09:27 pm
the TSOP1738 i bought dont hav any number on them.
i want to ask some questions ----
1. do i need 555 ic or 38khz cystall with the ir led ?
2. when i interchange the ground and vcc, i get a 3.54 vcc as output. is it working ?
also when i press the button of my sumsung tv remote there is a fall of 0.05/0.06 volts. is not it very less ?
3. in correct conditions and according to diagram i posted, i am getting a constant 0.6 volt as output and the receiver becomes very HOT. is this working?
4. then i change it to connection of TSOP 1838, the output is about 4.5 volt and when i press the button of tv remote, there is a drop of about 1 volt and i get about 3.5v output. is this the working condition ?
5. i connect the ir led to about 3 v and repeat the about three steps, but there is not volt change in the output, even after changing the ir led 3 times.is this the wrong way of sending ir signal ?
6. on net, i came across some threads in which they used a ic 555 or nand gate ic but i dont get the purpose.
plz tell me what to do now
[ Edited Thu Aug 07 2008, 09:30 pm ]
Thu Aug 07 2008, 10:40 pm
Yes you need ir pulses at 38kHz.Simply powering up the ir led won't work.
Just how could you do that!!! :-s
With active devices you NEVER swap gnd and +ve...that's elementary my dear Watson....
You probably have lost a few bucks here...
No...
With correct connections and without a 38k ir signal the output of the tsop should be ~5V.(Do use 5V for the tsop Vcc)
With a presence of ir signal from the remote,the output of tsop should be close to 0V(~250mV according to datasheet)
It's used to generate a 38kHz frequency for the ir led to be pulsed with.Without this the tsop won't work.
And finally RC5 works with a 36kHz modulation frequency...so you'd be better off with a 1736 if you are intending to use RC5.
btw have you visited the link Ajay posted in the previous page for line follower robot?
Thu Aug 07 2008, 11:06 pm
thanks for the information and help.
yes, but that person doesnot mention about 555 or nand ic but lm324.
i think lm324n is for converting the singal to 0 or 1 at desire signal.
can it be used instead of 555 ?
from the output from the question 5, i can assum it is correctly working. i dont used any capacitor and resistors which are mentioned in datasheet. so this could be the reason.
also if it is totally drop to zero that how people use then in measuring distance ??
please correct me if i am wrong.
update--- i used a different remote and on pressing button and also put a capacitor of 4.7uF, output droped from 4.7v to 0.6v.
also i dont want to use a rc5.i just use it to check the ir receiver. i will make the source using a 555 ic at 38khz.
[ Edited Fri Aug 08 2008, 12:05 pm ]
BillyTum
Tue May 14 2024, 09:08 am
Loganbag
Tue May 14 2024, 04:05 am
MichaelMog
Tue May 14 2024, 03:58 am
ThomasGaxaW
Mon May 13 2024, 05:33 pm
RobertInfup
Mon May 13 2024, 04:28 pm
Joshuatem
Mon May 13 2024, 08:30 am
RaymondPex
Mon May 13 2024, 03:24 am
Kennethbycle
Sun May 12 2024, 03:12 pm
