Lock bits
Tue Aug 05 2008, 07:45 am
For example, if u program the RSTDISBLE fuse of the ATmega8
Ponyprog version (latest) which i use doesn't allow this blunder to happen, it automatically blocks critical fuses like SPIEN and RSTDISBLE
Arun
nischay kumar like this.
Tue Aug 05 2008, 09:49 pm
thank you pid33 i was not aware of this RSTDIABLE bit will take care while i am programming next time
Tue Aug 05 2008, 11:41 pm
thanks arun,
Glad lancos took care of that.
I learnt this catch the hard way. I had already rendered two mega8 chips useless by accidentally setting that fuse.They are presently in a somewhat 'COMA' state .i.e. until i find a high voltage paralell programmer to bring them back to real working condition. .
Wed Aug 06 2008, 09:16 pm
yep, actually setting this fuse is a strict no-no using ISP. this fuse is specifically meant to be set/reset using high voltage parallel programming.
P.S. u can still set/reset the RSTDISBLE fuse by using the SETall/Clear all button on the ponyprog. So stay away from those buttons.
Thu Aug 07 2008, 12:24 am
i am using the latest beta, it does not show clear all, setall and RSTDISBLE of atmega32. also SPIEN is not selectable.
Thu Aug 07 2008, 08:23 am
thats a safety measure !
A beginner/novice might fiddle with the fuse bits and the device might get locked/unusable, ultimately Ponyprog would be blamed, thats why the designer of Ponyprog took the step to protect critical fuses.
Arun
[ Edited Thu Aug 07 2008, 08:24 am ]
