Need Serious Help
Fri Jan 16 2009, 01:56 pm
Please check that your rfid device is RS232 before connecting it to anything
Which rfid device is it ?.
Can you give a link to the C8051F350 board you are using ?.
Fri Jan 16 2009, 02:08 pm
the RFID I using is probably this :
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/txtSearch/28142/List/1/ProductID/114/Default.aspx?SortField=ProductName%2cProductName
the link for micro controller is this, it contain the data sheet of my micro controller :
http://www.keil.com/dd/chip/3682.htm
Fri Jan 16 2009, 02:31 pm
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/txtSearch/28142/List/1/ProductID/114/Default.aspx?SortField=ProductName%2cProductNamespiritgate
That device is TTL output (5volts).. so don't connect it to anything until
I/we have had a chance to think about it
http://www.keil.com/dd/chip/3682.htmspiritgate
What you have is a chip ( a C8051F350) soldered to a board with other chips
connectors etc.
The chips are all the same, but different makers make different boards.
Is this the board you have ?
https://www.silabs.com/products/mcu/Pages/C8051F350DK.aspx
[ Edited Fri Jan 16 2009, 02:44 pm ]
Fri Jan 16 2009, 02:51 pm
ya is this!
as for the RFId, will it go burst easily?
[ Edited Fri Jan 16 2009, 02:54 pm ]
Sat Jan 17 2009, 01:28 am
as for the RFId, will it go burst easily?spiritgate
It might if you connect it to the +12 and -12 volts of an
RS232 connection.
Connecting the output of the rfid to an RS232 input would not cause harm, but
would not work properly either.
Sun Jan 18 2009, 01:37 pm
its TTL compatible dont even think of connecting it to 12V interface..
Mon Jan 19 2009, 07:57 am
Very sad now, Left 4 weeks to finish this project... Guys u think 4 weeks can finish this project?
Mon Jan 19 2009, 08:45 am
Four weeks should be enough.
You'll have to insert a ttl to rs232 level converter,preferably based on MAX232,between the RFID reader and the expansion cable.
Look here : http://www.8051projects.net/serial-communication/introduction.php
Mon Jan 19 2009, 08:46 am
Ofcourse you can easily finish it out :-) we all here to help u out & u should try ur best.
check out this link for low cost RFID from Digant which is having UART and Wiegand o/p and works perfectly for micro-controller based application.
http://www.diganttechnologies.com/products_LF_1.html
:bye
:bye
