digital clock help required URGENT
Thu Oct 04 2007, 06:35 pm
see the ckt is the same as yours ..have attached it.. now the header file of LCD needs a few modifications..
i have highlighted a few that i think need to be changed.. plz help
Thu Oct 04 2007, 09:23 pm
well i never wrote such kind of code... as far as i know.. are you sure its my project?
Fri Oct 05 2007, 02:54 pm
ohh the code is not urs, i just thot you could explain the functioning of the code, as in just the fact that in that particular header file, which pins of the muC is used to send the D0 to D7 bits of the LCD..
it could be of great help!!
Fri Oct 05 2007, 04:11 pm
The LCD is used in 4-bit mode.... that means only D4-D7 pins of LCD are used... and they are connected to P0 as
D4 - P0.0
D5 - P0.1
D6 - P0.2
D7 - P0.3
Rest you can confirm from the circuit...
D4 - P0.0
D5 - P0.1
D6 - P0.2
D7 - P0.3
Sat Oct 06 2007, 06:42 pm
but i understand they use 0.0 0.1 and 0.2 for rs rw and en of LCD!!!
is this possible??
i surely will have to modify it right???
is this possible??
Sat Oct 06 2007, 09:26 pm
i am not getting you exactly.. are you trying to modify the code or what to understand the code?
Sun Oct 07 2007, 11:19 am
see for my muC project (digi clk) i am using your circuit. the one i had attached before. i wrote my own program in tri C. this tri C has a LCD header file that assumes a few ports of the muC to be connected to the control i/p of the LCD (rs rw en) and some port for passing the data bits.
i read the header file and understood that the control pins of the LCD are connected to 0.0 0.1 and 0.2 pins of the muC. i wanted to know which pins has the header file assumed to pass the data bits so that i can incorporate in my design.
Sun Oct 07 2007, 02:00 pm
this header file lets me initialize the lcd, pring char on LCD and other fnctions
