Discussion in "Project Help" started by    elie    Sep 27, 2007.
Fri Oct 05 2007, 01:50 pm
I don't think you've read the code properly.. did you add the components as described in the code? Like buttons, textboxes forms etc...?
Sat Oct 06 2007, 01:09 am
yes.. i did all what it said in the code.. but it doesn't work what should i do?
Sat Oct 06 2007, 01:42 am
well it worked with me...
anyways i am attaching the VB project.. check it out
Sat Oct 06 2007, 01:49 am
Sat Oct 06 2007, 01:09 pm
hi again ajay ..
what does this means?
IMPORTANT: PLEASE CHANGE THE MSCOMM1 SETTINGS ACCORDING TO THE COM PORT AVAILABLE ON YOUR PC.
i dont understand it.. can u explain it to me..
thank u again..
Sat Oct 06 2007, 05:01 pm
check your device manager to see the name of your serial ports....
in some pcs you will find lots of com ports available....
com1
com2
com3...etc.... mostly happens when u are using laptops with bluetooth and wi fi....
so do confirm the name of your com port at which the f-bus cable is to be connected...... :-)
Sat Oct 06 2007, 05:14 pm
usually its either COM1 or COM2..
in the SMS.frm you see MSCOMM1 icon.. click on its properties and change the COM port number whichever is available on your PC.
 elie like this.
Sun Oct 07 2007, 01:49 am
9600,n,8,1 this is the default settings on my com1.. do i have to change it?
Sun Oct 07 2007, 10:09 am
yes.. change it to whatever port available and 115200,n,8,1
Tue Oct 09 2007, 04:30 pm
ajay..
still not working..
what does this means..
set different FBUS sequence number..
help me please..
FrancisaHiz
Sun Sep 24 2023, 05:58 pm
azCar
Sun Sep 24 2023, 01:47 am
ChrisBUP
Sat Sep 23 2023, 03:06 am
Kevinric
Fri Sep 22 2023, 10:39 pm
DarylLor
Fri Sep 22 2023, 05:09 pm
liaifat85
Fri Sep 22 2023, 04:17 pm
RobertoMix
Fri Sep 22 2023, 03:39 pm
Bradleyedusa
Fri Sep 22 2023, 02:05 pm
