Beginner and huge enthusiast...but need help!!!
Sat Oct 06 2007, 03:47 pm
its asking for an add on disc wat do i do now! wat does that mean? n shyam if its not right il close this topic wont discuss about it here...well cant share it the i guess
hell wat do i do now???
Sat Oct 06 2007, 04:54 pm
nothing yaar...........
look if it is a full version then you will find an .addon named folder in the setup folder.....
just browse .....
at first it will ask you to insert drive an a:
cancel and select your .addon folder from your installation folder......
if you could not find addon folder....
search for it ......
u'll surely get.....
and hey every body has full version of keil but its may be cracked or illegaly obtained.....
so be specific and call it cracked keil .....
i dont know wether we are supposed to use that word ....
if ajay feels okay ..then fine... or the posts will be edited ... do not worry
just browse .....
Amit Radha like this.
Sat Oct 06 2007, 05:10 pm
well.. better stop talkin about the software.. get to the topic.
@Amit (edited):
You asked about why use RD2.. so the reasons are many..
1. No special programmer needed
2. More RAM
3. More ROM (64K)
4. Easy to program
5. fast speed (6 clock or 12 clock)
6. Dual DPTR
Just check out the datasheet there are many things about RD2. I think for you its best suited as you cannot afford a programmer right now. So better use this.. later when you get to know about these stuff you can make use of other controllers..
RD2 will be good for you as a learner..
@Amit (edited):
2. More RAM
3. More ROM (64K)
4. Easy to program
6. Dual DPTR
[ Edited Sat Oct 06 2007, 06:13 pm ]
Sat Oct 06 2007, 05:22 pm
hey ajay thnx for the rd2 intro...
by the way never asked for it....
justed wanted amit to save money spending on rd2 and suggested him to work on simulators.....
get the basics done and then .... depending on his resources...
he should choose either rd2 or the programmer....
Sat Oct 06 2007, 06:10 pm
OOPS! that intro was for Amit
I am gonna edit it..
its his decision ultimately we are here for advice and all possible suggestions
[ Edited Sat Oct 06 2007, 06:12 pm ]
Sat Oct 06 2007, 07:21 pm
thanks for al the info. as iv got keil now (evaluation version only ) i guess il work with that for a while. anythin specific i must keep in mind? am just unable to figure out how to use this but i wil in some time thanks once again...n soon il get down to the h/w
[ Edited Sat Oct 06 2007, 07:25 pm ]
gr8 going.........
after all u have started.....
now open c:\keil\c51\example\blinky
and study it...
and study it...
Sat Oct 06 2007, 07:33 pm
hey that file/folder is not there in the path u mentioned. examples is there but there is no blinky or blink in it..wat do i do
