need help for GPS tracking through GPRS
Tue Feb 02 2010, 11:04 pm
I came across this item.
http://www.nskelectronics.in/gsm_kit.html
They might sell the I/O board on its own.
Wed Feb 03 2010, 02:33 am
They might sell the I/O board on its own.ExperimenterUK
I think this site is just a joke: 2750.00 € for a simple EVB-kit!! o_O
Worth to make his own..
Wed Feb 03 2010, 02:45 am
Worth to make his own..mutonic
I read it as Rupees
GSM MODEM GSM&GPRS WITH POWER SUPPLY 2750.00 Rs
[ Edited Wed Feb 03 2010, 02:50 am ]
Wed Feb 03 2010, 04:53 am
hey can any one ans me , is this site reliable ??
Wed Feb 03 2010, 12:40 pm
Can this antenna be used for the sim300?
Check it out pls, and let me know asap.
http://my.farnell.com/multicomp/ir-gsmqb-00-c5/antenna-gsm-quad-band/dp/1735189
thanks.
Fri Feb 05 2010, 01:43 am
why dont you contact store or vendor where you bought modem from? I feel that antenna should be fine.
Sat Feb 06 2010, 02:55 am
thanks.VioletRock
It looks okay. You have to be careful to get the right connector though.
The one you asked about is
Connector Type:SMA.
This is common ,but there are other sizes.
You will still need a "pigtail" to connect to the modem itself, such as this one
http://www.soselectronic.com/?str=371&artnum=53551
I can't vouch for the item or the site, it is just an example
Mon Feb 08 2010, 10:50 am
Is this the same connector for the antenna, can I use this one?
http://bit.ly/bgg1zS
Mon Feb 08 2010, 09:46 pm
http://bit.ly/bgg1zSVioletRock
Probably...
The SIMCON connector is described as a Murata MXTK while the ebay item is
a Hirose Electric Group type U.FL
However this link
suggests that they are the same.
Best to ask the ebay seller,they should be able to tell you for sure.
[ Edited Mon Feb 08 2010, 09:53 pm ]
Tue Feb 09 2010, 12:18 pm
is there some kind of socket or holder for the SIM300 that can make it easier for soldering?
I tried asking the ppl at my lab, but they don't do surface soldering.
If there is, what is it called?
