Discussion in "8051 Discussion Forum" started by    shaik    Aug 3, 2010.
Wed Aug 18 2010, 10:06 pm
yep table is fine now
ADC o/p value may vary +/- 2 so write code accordingly good luck!
 shaik like this.
Thu Aug 19 2010, 05:31 pm
hello ajay,
Thanks for ur reply.
I write the program as follows.
#include <stdio.h>
#include "reg_c51.h"
  // standard conversion
 // The variable "channel" contains the channel to convert
 // The variable "value_converted" is an unsigned int
#define channel P1_7	 // ADC i/p
#define value_converted P0 // ADC o/p
	ADCF = 0x80;  // configure channel P1.7 for ADC
	ADCON = 0x20;  	// Enable the ADC
	ADCON  &= 0xF8;    // Clear the field SCH[2:0]
	ADCON |= channel;    // Select channel
	ADCON |= 0x08;   // Start conversion in standard mode
        // Wait flag End of conversion
	while((ADCON & 0x01)!= 0x01)
		ADCON &= 0xEF;// Clear the End of conversion flag
                // read the value
		value_converted = (ADDH << 2)+(ADDL);
	while (1)
In this program my analog i/p pin is p1_7 [pot-R12] and o/p port is P0.
I can give analog i/o through P1_7 pin but no o/p given by port P0.
I don´t know why?
I have clearly write
then why this program not give o/p?
Please check this program.
Tell me ur idea or sugestion for this problem.
Thanks in advance.
Fri Aug 20 2010, 12:45 am
wrong statement..
while((ADCON & 0x01)!= 0x01){} //wait here
// read the value
can you explain how you are reading this value? P0 is an 8bit port and you are moving a value higher than 8-bit. so be careful. ok?
 shaik like this.
Fri Aug 20 2010, 12:46 am
Fri Aug 20 2010, 12:52 pm
hello ajay,
thanks for ur reply.
As u say that there is no problem in program upto first 5 statements.
I had again read the ADC section in datasheet. In that for getting ADC o/p byte ADDL register contains 2 bits of Low byte and ADDH register contains High byte, so for copy ADDL value into ADDH i have to write like this for shifting 2 bits.
ADDH << 2;
ADDL << 2;
ADDH << 2;
ADDL << 2;
and after shifting i have to concate both register into ADDH and give this value to Port P0.
like
P0 (value_converted) = ADDH + ADDL;
Am i right upto this?
if yes then is there problem in flag loop or clearing flag statement?
please check the following code.
	ADCON &= 0xEF;
	// read the value
	//value_converted = (ADDH << 2)+(ADDL);
        value_converted = ADDL;
	value_converted += (ADDH << 8);
please give me ur suggetion for this problem.
thanks in advance.
[ Edited Fri Aug 20 2010, 07:04 pm ]
Sat Aug 21 2010, 12:38 am
i have already posted the correct flag statement.. please read comments too when i post code.
value_converted should be declared as unsigned int as your result is more than 8 bits so you need a bigger variable. unsigned int is 16-bit so it can store result easily..
unsigned int value_converted;
// read the value
value_converted = ADDH;
value_converted = (value_converted << 2)+(ADDL);
//now do whatever you want to do with value_converted
//another way to debug your code is to print ADC value on serial port.
 shaik like this.
Mon Aug 23 2010, 02:26 pm
#27
hello ajay,
i had change in my program and now the code is as follows
#include <stdio.h>
	unsigned int value_converted;  // ADC o/p
	{}  	// Wait
	ADCON &= 0xEF; // Clear the End of conversion flag
	value_converted = (ADDH<<2 )+(ADDL); // read the value
	printf("%d",value_converted);
	P0 = value_converted;
	while (1)
I had one daut that when i write unsigned int value_converted; // ADC o/p then this variable contains 4 bytes = 16 bits, but for o/p i have only 8 bits in P0 pin P0 = value_converted;
In C none datatype contains 3 bytes for variable.
so is it possible to give 4 byte i/p for 8 bits o/p?
I set P0 for ADC o/p.I had run this program first in "Logic Analyser", but i not get any o/p in that, like some pins are 0 and some are 1.
Then i try to print the ADC decimal value on "Terminal", but it´s also not give any o/p value.
Is this statment is right if i want to assign ADC o/p value on P0 port P0 = value_converted;
I don´t understand wht is the problem?
please give me ur sugestion for this problem.
Thanks in advance.
Mon Aug 23 2010, 04:56 pm
#28
4 bytes = 16 bits <<<< errr... wrong
16bits is 2 byte
correct thats the reason i said not to use port for checking o/p better use uart.
please give me ur suggestion for this problem.
Thanks in advance.
you forgot to initialize your serial port before sending data to it. unitize uart then use printf.
 shaik like this.
Mon Aug 23 2010, 06:35 pm
#29
hey ajay,
oh..sorry for my misunderstanding.
1 byte = 8 bits.
Is there any another option for getting perfect o/p for 8 bits without UART?
Bcoz i don´t know much abt UART.
How can i write program using UART?
I know only full form of UART (Universal Asynchronious Receiver and Transmitter)
how can i initialize serial Port?
please give ur sugetion for this problem.
Thanks in advance.
Mon Aug 23 2010, 06:45 pm
#30
use two ports to instead of using 1.
your data is 10 bit, use 8 bits of P0 and 2 bits of any other port.
lets say you are using P0 and P2 so..
P2 = (value_converted >
 8);
try it.. use any free port you have in your board.
 shaik like this.
MnoioCoove
Tue May 21 2024, 02:06 am
PedroDug
Sun May 19 2024, 05:39 pm
JewelAmuck
Sun May 19 2024, 03:06 pm
Minniemus
Sun May 19 2024, 07:39 am
Andyhet
Sat May 18 2024, 07:28 am
BrettTibre
Fri May 17 2024, 06:14 pm
Gordonfax
Fri May 17 2024, 10:28 am
Davidspils
Fri May 17 2024, 10:19 am
