Interfacing 8 bit lcd to keypad using assemley language
Thu Jan 03 2008, 07:41 pm
I serious dont have any idea.. why its not working.. just try one more time replace this routine..
;********************************************************** ; Feed Command/Data to the LCD module ;*********************************************************** ;*********************************************************** command_byte: clr p2.0 ; RS low for a command byte. jmp bdelay data_byte: setb p2.0 ; RS high for a data byte. nop bdelay: clr p2.1 ; R/w low for a write mode setb p2.2 ;enable pulse nop clr P2.2 ;enable H-> L nop ;******************* Check Busy Flag ;mov p1,#0ffh ;configure port1 to input mode ;no need to make all lines 1 just make the bit 7 as inout setb P1.7 setb p2.1 ;set RW to read clr p2.0 ;set RS to command bloop: clr p2.2 ;generate enable pulse nop setb p2.2 nop ;mov a,p1 ;anl a,#80h ;check bit#7 busy flag ;cjne a,#00h,bloop;keep waiting until bu jb P1.7 ,bloop ;jump if P1.7 is 1 ;***************************************** ; check busy flag twice ;***************************************** ;bwait: ;clr p2.2 ;generate enable pulse ;nop ;setb p2.2 ;nop ;mov a,p1 ;anl a,#80h ;check bit#7 busy flag ;cjne a,#00h,bloop;keep waiting until bu ;There is no need of above commented code... ret
Thu Jan 03 2008, 08:06 pm
i dont know what is wrong with this code..do you think it is the initialisation process??? have you got a different code that i can use????
thanks
thanks
Fri Jan 04 2008, 02:43 am
please can you compile and check it...please...i have been working on this for 3 days straight and i cant see were the problem is....please...because my lcd does not anything...please help me on this..
thank you
thank you
Fri Jan 04 2008, 03:09 am
As soon as i get time.. i will do that too.. by the time.. please take a close look at the explanation of working of LCD in LCD tutorial.. you must go through it once.. analyze your code and see where you are doing mistake
