Discussion in "General help Guidance and Discussion" started by    Mamat    Nov 4, 2010.
Wed Feb 23 2011, 07:34 pm
#41
thanks exUK
hmm. i already search other 3.3v rs232 drivers like st3232 but still not have in my place.
so i decide to used max323 running with 5V and xbee 3.3V
it ok ajay? i hope it will fine
haha
Fri Apr 01 2011, 01:52 am
#42
Posted: Fri Apr 01 2011, 01:47AM
HI all
i ve been suffering in running a simple XBEE transmission and reception module need all your advice and help
TX code : will transmit T char and receiver code is coded to display the transmitted code
ill attach my code and circuit
# i really don know whtr the XBEE is transmitting something or not
# in the circuit i made sure that max 3232 15th pin is grounded
# Used the 9 0 9 1A transformer for the bridge
# also isolated the AC power removed the 5v and 3.3v regulator and now using PC smps for voltage to ensure little noise in the PCB
# i don have OSC'scope to measure
i have attached the TX code and RX code ....
also the circuit and the gerber i deisgned for this module ...
please help
Regards
Venkat.S
RobertNax
Wed Mar 22 2023, 10:33 am
nisCar
Wed Mar 22 2023, 07:52 am
BruceuricT
Tue Mar 21 2023, 03:47 pm
WillieemetS
Sun Mar 19 2023, 03:09 pm
Ricardopaura
Sat Mar 18 2023, 03:04 pm
Marcusabsot
Fri Mar 17 2023, 06:50 pm
Brianraing
Fri Mar 17 2023, 03:41 am
unreago
Thu Mar 16 2023, 04:50 pm
