dc motor control with 89s52
Mon Dec 31 2007, 12:11 am
ok i understand and i can change its value but my problem is interrupt... i will send you my codes soon...
Mon Dec 31 2007, 01:31 am
$include(REG51.inc) STATUS_file EQU 20h ; STATUS_file.0 =1 turn right 0 turn left bit.1=1 turn 0 stop bit.2=1 from1 interrupt 0 from0 interrupt DT EQU 21h MAX-DT EQU 22h MIN_DT EQU 23h L293B_4A equ P1.0 ; MOTOR turn right L293B_3A equ P1.1 ; MOTOR turn left L293D_E equ P1.2 ORG 2000h jmp START ORG 000bh jmp ISR ISR: MOV DT,#125 CLR TR0 CLR TF0 JNB STATUS_file.2,BIRLE JMP SiFiRLA BIRLE: setb STATUS_file.2 CJNE A,#'K',AZALT_1 JMP ARTTIR_1 AZALT_1: ;from 0 interrupt CJNE A,#'L',BIRLE MOV A,DT INC A MOV TH0,A ret ARTTIR_1: MOV A,DT DEC A MOV TH0,A ret SiFiRLA: CLR STATUS_file.2 CJNE A,#'K',AZALT JMP ARTTIR AZALT: ;from 1 interrupt CJNE A,#'L',SiFiRLA MOV A,DT DEC A MOV TH0,A ret ARTTIR: MOV A,DT INC A MOV TH0,A ret reti START: SETB ETO ;TIMER 0 work MOV TMOD,#10h ;TIMER 0 configuration SETB TR0 MOV TLO,#255 MOV MIN_DT,#25 MOV MAX_DT,#250 CLR STATUS_file MOV TH1,#0FDH MOV TL1,#0FDH ORL 87h,#080h ;SMOD 1 MOV SCON,#048h MOV TMOD,#020h SETB TR1 CLR RI BEKLE: SETB REN LCALL GETCH CLR REN CJNE A,#'N',SOL_BAK ;CALIS CALL SAG SOL_BAK: CJNE A,#'T',B_BAK ; SAG CALL SOL B_BAK: CJNE A,#'R',BEKLE ; SOL CAll DUR GETCH: JNB RI,$ CLR RI MOV A,SBUF RET PUTCH: JNB TI,$ CLR TI MOV SBUF,A RET SAG: CALL PUTCH setb L293D_A ;Make Positive of motor 1 clr L293D_B ;Make negative of motor 0 setb L293D_E ;Enable to run the motor ret ;Return from routine SOL: CALL PUTCH clr L293D_A ;Make positive of motor 0 setb L293D_B ;Make negative of motor 1 ret ;Return from routine DUR: CALL PUTCH clr L293D_A ;Make Positive of motor 0 clr L293D_B ;Make negative of motor 0 clr L293D_E ;Disable the o/p ret ;Return from routine END
[ Edited Mon Dec 31 2007, 01:27 pm ]
Mon Dec 31 2007, 01:45 pm
there are few mistakes in your code.
and there are few thing which i do not understand..
i am going to comment it so explain them to me
The first main and serious mistake is.. you are not using RETI while coming back from interrupt routine.. and interrupt routine seems to be worng..
What exactly you are doing in your ISR? i cant understand..
ISR: MOV DT,#125 CLR TR0 CLR TF0 JNB STATUS_file.2,BIRLE JMP SiFiRLA BIRLE: setb STATUS_file.2 CJNE A,#'K',AZALT_1 JMP ARTTIR_1 AZALT_1: ;from 0 interrupt CJNE A,#'L',BIRLE MOV A,DT INC A MOV TH0,A ret ;RETI ARTTIR_1: MOV A,DT DEC A MOV TH0,A ret ;RETI SiFiRLA: CLR STATUS_file.2 CJNE A,#'K',AZALT JMP ARTTIR AZALT: ;from 1 interrupt CJNE A,#'L',SiFiRLA MOV A,DT DEC A MOV TH0,A ret ;RETI ARTTIR: MOV A,DT INC A MOV TH0,A ret ;RETI should be used reti ;there is no use of this Return instruction
Mon Dec 31 2007, 05:54 pm
:D:D this is second version of my codes. first version can turn the motor right,left and can stops the motor. i tried to write interrupt section and i see it in my book. ISR is interrupt section i mean when user pushs a button the program must go ISR section. I now its wrong . if you want i can send you first version so you can say how can i add interrupt and pwm??
Mon Dec 31 2007, 06:05 pm
u can have interrupt and PWM.. not a problem.. just keep ur ISR small.. and.. increase the priority of timer interrupt..
you actually do not need any interrupt for reading buttons in your code..
if you have taken a look at the fan control project in the same post where i posted the PWN code you will come to know how to use PWM..
i give you the link.. go through the program. do not care about the temperature thing.. just see how the manual part works..
http://www.8051projects.net/forum-t2321-post.html
see fanlow routine.. here i am loading R7 with a value.. with your project. this value need to be changed when button is pressed.. either increase it or decrease it..
and timer0_int is the PWM code.. read it carefully
[ Edited Mon Dec 31 2007, 06:05 pm ]
Mon Dec 31 2007, 06:11 pm
i know when reading buttons, i want to use interrupt for PWM when pushing speed up button ....
thank alot i try to understand code which your post...
Mon Dec 31 2007, 06:21 pm
i think this program cant be fan speed done because it have never jump low_done just speed up ... am i right i try to do this way but i cant complete the code :S
Mon Dec 31 2007, 07:02 pm
i will try to edit your code.. to make it work with PWM..
i really don't know how your circuit looks like..
and coz of difference in language.. i cant understand the labels
hope we can workout something..
Mon Dec 31 2007, 08:14 pm
i am translating:D:D:D
BIRLE: SETB (means make logic 1)
AZALT: DECRESE
ARTTIR: INCRESE
SiFiRLA: CLEAR
BEKLE: WAIT
SAG:RIGHT
SOL:LEFT
DUR:STOP
i use L293B to control motor and h bridge thanks a lot
AZALT: DECRESE
ARTTIR: INCRESE
SiFiRLA: CLEAR
BEKLE: WAIT
SAG:RIGHT
SOL:LEFT
DUR:STOP
