remotely controlling devices using microcontroller
Discussion in "Project Help" started by anantharaman Dec 28, 2007.
Sun Dec 30 2007, 01:09 am
anantharaman
u can get T290i.its very cheap , u can get a second hand set in nearly 1000 Rs/- ( i got in 900 ). and it is also easy to work wid
Sun Dec 30 2007, 09:05 am
can u help me by posting some relavent circuit diagrams or some pictures of similar projects..........please give an idea about the choice of the microcontrollers and the coding logic(in C) ...i will like to use it as a reference only
Sun Dec 30 2007, 03:31 pm
click on image to view full image
circuit by abbas
[ Edited Sun Dec 30 2007, 03:35 pm ]
Sun Dec 30 2007, 04:11 pm
thanks .....and i also want to know how you programmed the micro ......is it through the parallel port of the computer
Sun Dec 30 2007, 05:55 pm
programming is done using a programmer.. you can use any available with you.
