Discussion in "ARM Development" started by    shyam    Dec 29, 2007.
Sat Apr 03 2010, 07:06 pm
Nevermind, I fixed the problem by enabling FIFOs
Tue Jun 14 2011, 02:31 am
please can anyone explain to me where we can use RXD0 and TXD0 ???
Sat Jul 09 2011, 02:04 pm
hi
m trying to setup Uart1 of lpc2148 to receive byte using interrupt
i have written d code for it
when a byte is rxd interupt occurs isr function is executed correctly but only 1 time.
when anohter byte is sent execution doesnt enter isr. m sure there might b a problem with my code but m not able to find 1
code
main.c:
#include "lcd.h"
#include "test.h"
#include "serial.h"
int main (void)
init_lcd();
Test_Lcd();
Uart1_Init();
Uart1_Tx('A');
while (1)
serial.c:
#include <LPC21xx.H>
#include "lcd.h"
#define TEMT (1<<6)
// Function name : Uart1_Tx
// Parameters : unsigned char Tx_Data
// Return Parameter : None
// Description : Transmits the Tx_Data to Uart1
void Uart1_Tx(unsigned char Tx_Data)
while(!(U1LSR & TEMT));
U1THR = Tx_Data;
// Function name : Uart1_Irq
// Parameters : None
// Description : Uart1 Rx ISR
void Uart1_Irq()
unsigned char Data;
lcd_putstring(0," Uart1 IRQ ");
Data = U1RBR;
Uart1_Tx(Data);
VICVectAddr = 0; //end of interrupt
lcd_putstring(1," done ");
// Function name : Uart1_Init
// Description : Initializes Uart1 for 8 data bit, 1 stop bit
// no parity and 9600 Baud rate*
void Uart1_Init()
PINSEL0 = 0x00050000; //init pins for uart1 rxd1 & txd1
U1LCR = 0x83; //8bit data, 1 stop bit, no parity
U1DLL = 97; //9600 baud rate
//U1DLL = 24; //38400 baud rate
U1LCR = 0x03; //dlab disable
U1IER = 0x01; //Uart1 RBR interrupt enable
VICProtection = 0; //Diable protection
VICIntSelect &= 0xffffff7f; // select Uart1 Interrupt as IRQ
VICVectAddr0 = (unsigned int)Uart1_Irq;//Assigning isr Addr
VICVectCntl0 = 0x20 | 7;
VICIntEnable |= 0x00000080; //enable uart1 interrupt
plz help find missing code
thanks n regards
naqsh
Sat Jul 09 2011, 03:16 pm
sorry
i found d issue
i had missed adding __irq to void Uart1_Irq()
ie Uart1_Irq() __irq{
so plz ignore
thanks anyways
regards
naqsh
Thu Jan 12 2012, 12:33 pm
Excellent tutorial @Shyam. I am a newbie to ARM .Things seem clearer to me.. I could not find a continuation link to the above thread. pls post if any.
link for the thread:
www.8051projects.net/forum-t4311-10.html
[ Edited Thu Jan 12 2012, 12:35 pm ]
Wed Jan 18 2012, 06:55 pm
Pawankumar
Which link are you talkin about? Please let me know I will look into it.
Mon Jan 23 2012, 09:35 pm
hi Ajay,
the thread is : ARM tutorial : UART
link for the thread is: http://www.8051projects.net/forum-t4311-0.html
its a great tutorial. shyam has closed the thread without discussing the following as proposed
4.sending a byte of data.
5. receiving a byte of data.
6. using in interrupt.
7.difference between polled and interrupt mode
or am I lost somewhere?
P.S: am not able to use the hyperlink option excuse me.
Tue Jan 24 2012, 10:09 am
hi can any1 plz guide me to setup printf function to work with uart using stdio.h?
i did some trial n error but didnt find success. so waiting for reply
regards
naqsh
Tue Jan 24 2012, 09:45 pm
Tue Jan 31 2012, 10:39 pm
please help . I am trying to interface GPS module with LPC2148. I have written a code to get data from GPS through UART1 and send it to hyperterminal through UART0. This code does not work. where am i wrong?
#include<lpc214x.h>
void inituart1()						  //initializes both UARTS at 9600 baud
U1LCR=0x83;
U1DLL=0x61;
U1DLM=0x00;
U1LCR=0x03;
U0LCR=0x83;
U0DLL=0x61;
U0DLM=0x00;
U0LCR=0x03;
void send(unsigned char a)							//sends a byte through U0
U0THR=a;
while(U0LSR!=0x60);
void senduart1(unsigned char a)						  //sends a byte through U1
U1THR=a;
while(U1LSR!=0x60);
unsigned char recuart1()										// recieves a byte from U1
unsigned char p;
while ((U1LSR&0x01)!=1);
p=U1RBR;
return p;
unsigned char rec()											// recieves a byte from U0
unsigned char p;
while ((U0LSR&0x01)!=1);
p=U0RBR;
return p;
int main()
PINSEL0=0x00050005;								   //initialized U0 and U1 as UART and not GPIO
PINSEL1 = 0x00000000;
PINSEL2 = 0x00000000;
inituart1();
send(recuart1());
[ Edited Tue Jan 31 2012, 10:45 pm ]
StephenHauct
Sat Apr 27 2024, 09:38 am
Adamsaf
Sat Apr 27 2024, 07:12 am
