PIC16F876 4 bits Display in 16x2 LCD
Discussion in "PIC Microcontroller Discussion" started by pappuneelam May 1, 2011.
Sun May 01 2011, 11:59 am
Halo!
The below mentioned ASM code is for 4 bit LCD display with 16F876A. Using RB0,RB1,RB2 for RS,R/W,E and RC0,1,2,3 for DB4,DB5,DB6,DB7 of LCD.
My problem is that the code is working on OshonSoft simulator with only 'A 0', i.e. where as it should print 'R1'. Moreover, there is a blank space between A and 0. Its taking the MSB of the A first and then taking 0000 in the next sending of LSB.
Also, not getting any display over with PIC16F876A & LCD panel.
I tried in vein, but not geting any solution. Please help me.
PappuNeelam
PappuNeelam
; 4 bit interface with LCD 16x2, using PIC 16F876A ; using PORT B: RB0, RB1 & RB2 as RS, R/W & E line ; using PORT C: RC0, RC0, RC2 RC3 as DB4, DB5, DB6 & DB7 __CONFIG H'39B1' ; set the configuration word ; ***************** Set up the constants ************************** STATUS equ 03h TRISA equ 85h TRISB equ 86h TRISC equ 87h PORTA equ 05h PORTB equ 06h PORTC equ 07h COUNT1 equ 20h ;counter1 for delay loop COUNT2 equ 21h ;counter2 for delay loop COUNT3 equ 22h ;counter3 for delay loop COUNT4 equ 23h ;counter4 for delay loop COUNT5 equ 24h ;counter5 for delay loop COUNT6 equ 25h ;counter6 for delay loop COUNT7 equ 26h ;counter2 for delay loop COUNT8 equ 27h ;counter3 for delay loop ; *******Ports setup ******* org 00h bsf STATUS,5 ; shift to Bank1 movlw 00h movwf TRISB ; set PortB to output mode movlw 00h movwf TRISC bcf STATUS,5 ; return to Bank0 ; ******Turn the Port pins ******* Start call Delay call Init movlw 05h movwf PORTC call Data_control call Delay1 movlw 02h movwf PORTC call Data_control call Delay1 movlw 03h movwf PORTC call Data_control movlw 01h movwf PORTC call Data_control call Loop ; ******** Command & Data Function ******** Command_control movlw 04h movwf PORTB ; use RB0,RB1,RB2 for RS,R/W,E call Delay1 movlw 00h movwf PORTB return ; ******** Data Function ********* Data_control movlw 05h movwf PORTB ; use RB0, RB1, RB2 for RS,R/W,E call Delay1 movlw 01h movwf PORTB return ;********* Functions Definitions******** Init movlw 20h movwf PORTC call Command_control call Delay1 movlw 00h movwf PORTC call Command_control call Delay1 movlw 0Fh movwf PORTC call Command_control call Delay1 return ;************* Delay subroutine - 4mS interval ***************************** Delay loop1 decfsz COUNT1,1 ; decrease 1 from 255 goto loop1 loop2 decfsz COUNT2,1 ; decrease 1 from 255 goto loop2 loop3 decfsz COUNT3,1 ; decrease 1 from 255 goto loop3 loop4 decfsz COUNT4,1 ; decrease 1 from 255 goto loop4 loop5 decfsz COUNT5,1 ; decrease 1 from 255 goto loop5 loop6 decfsz COUNT6,1 ; decrease 1 from 255 goto loop6 loop7 decfsz COUNT7,1 ; decrease 1 from 255 goto loop7 loop8 decfsz COUNT8,1 ; decrease 1 from 255 goto loop8 return ;************* Delay1 subroutine - 1.5mS interval ***************************** Delay1 loop9 decfsz COUNT1,1 ; decrease 1 from 255 goto loop9 loop10 decfsz COUNT2,1 ; decrease 1 from 255 goto loop10 return Loop loop13 decfsz COUNT1,1 ; decrease 1 from 255 goto loop13 incfsz COUNT1,1 ; decrease 1 from 255 goto loop13 return end ; end of the program
Sun May 01 2011, 03:14 pm
Sorry;
Its displaying 'P 0' (not 'A 0'), instead of 'R1'. There is a blank space between P and 0.
PappuNeelam
PappuNeelam
Mon May 02 2011, 02:28 pm
Start
call Delay
call Init
movlw 05h
movwf PORTC
call Data_control
call Delay1
movlw 02h
movwf PORTC
call Data_control
call Delay1
movlw 03h
movwf PORTC
call Data_control
movlw 01h
movwf PORTC
call Data_control
call Loop
Through this, i`m getting prints in the LCD of OshonSoft simulator. Inspite of getting 'R1', its displaying 'P--0' & having a two blank spaces between P & 0.
PappuNeelam
Start
call Delay
call Init
movlw 05h
movwf PORTC
call Data_control
call Delay1
movlw 02h
movwf PORTC
call Data_control
call Delay1
movlw 03h
movwf PORTC
call Data_control
movlw 01h
movwf PORTC
call Data_control
call Loop
PappuNeelam
Mon May 02 2011, 10:02 pm
try this..
movlw 'R' ;then call lcd function movlw '1' ;call lcd data function
Tue May 03 2011, 11:10 am
Mr. Ajay,
I tried with your suggestion. But, now its printing nothing, except blanks. Its now taking LSB of R[52]0101 0010 as MSB of Blank space [0010 0000]. And I tried with S[53]0101 0011, but printing is '0'.
I thing, there is some wrong in my ASM code.
Fri May 06 2011, 06:30 pm
; Program for LCD HD44780 display
; Using XT 4Mhz
;Declaration and Configuration of the processor
PROCESSOR PIC16F876A
#include <P16F876A.inc>
; ************* Macros & Constants ***********
BANK0 macro
Bcf STATUS,RP0 ;Select memory bank 0
Endm
BANK1 macro
Bsf STATUS,RP0 ;Select memory bank 1
Endm
; ********* Ports setup ************
ORG 00h
goto Main
Main
BANK1
movlw 00h
movlw 00h
movwf TRISC
BANK0
; *************Sending Data to LCD***************
call Delay
call Init
movlw 'R'
movwf PORTC
call Data_control
call Delay
call Loop
; ************** Command Function *************
Command_control
movlw 04h
call Delay1
movlw 00h
movwf PORTB
return
; ************** Data Function ****************
Data_control
movlw 05h
call Delay1
movlw 01h
movwf PORTB
return
;************** Initialise Function ************
Init
movlw 20h
movwf PORTC ; Function Set for 4 bits, 2 lines, 5x7 dots
call Delay
movlw 02h
movwf PORTC
call Delay
movlw 00h
movwf PORTC
call Delay
return
;************* Delay subroutine :2mS *****************************
Delay
goto loop1
goto loop2
goto loop3
goto loop4
return
;************* Delay1 subroutine :1mS ****************
Delay1
loop5 decfsz COUNT1,1 ; decrease 1 from 255
goto loop5
loop6 decfsz COUNT2,1 ; decrease 1 from 255
goto loop6
return
; *********** Hold the Program ******************
Loop
loop7 decfsz COUNT1,1 ; decrease 1 from 255
goto loop7
incfsz COUNT1,1 ; increase 1 to 1
goto loop7
return
Sat May 07 2011, 12:26 am
Your 4-bit initialization of LCD is not right. I suggest you to visit tutorial section and read about 4-bit mode of LCD. That will give you a clear idea of where you're doing wrong.
Mon May 09 2011, 05:57 pm
Mr. Ajay,
As per ur suggestion, I changed my Initialisation section for 4 bits. and its now working well on Simulator. But, I haven`t checked on physical devices. I will try on weekends. Thanks a LOT !!!!!!!!
But, no instruction/commeands are working or any effects on the code, like.. 0Fh, 0Eh,01h,C0h.
The 0Fh, 0Eh are need to be in Initialisation subroutine, but no effect.
The 01h,C0h are need after printing any data.
; Program for LCD HD44780 display ; Using XT 4Mhz ; Using PIC16F876A ;*****************PORT Pins ********************************* ; Using RA1,RA2 [PORTA] for RS & R/W pins of LCD ; Using RB0 [PORTB] for E pins of LCD ; Using RC0,RC1,RC2,RC4 for D4,D5,D6 & D7 pins of LCD ;************************************************************ ; Declaration and Configuration of the processor PROCESSOR PIC16F876A #include <P16F876A.inc> __CONFIG H'39B1' ; set the configuration word ; ************* Macros & Constants *********** BANK0 macro Bcf STATUS,RP0 ;Select memory bank 0 Endm BANK1 macro Bsf STATUS,RP0 ;Select memory bank 1 Endm COUNT1 equ 20h ;counter1 for delay loop COUNT2 equ 21h ;counter2 for delay loop COUNT3 equ 22h ;counter3 for delay loop COUNT4 equ 23h ;counter4 for delay loop COUNT5 equ 24h ;counter5 for delay loop COUNT6 equ 25h ;counter6 for delay loop COUNT7 equ 26h ;counter7 for delay loop COUNT8 equ 27h ;counter8 for delay loop COUNT9 equ 28h ;counter9 for delay loop COUNT10 equ 29h ; ********* Ports setup ************ ORG 00h goto Main Main BANK1 movlw 00h movwf TRISA ; set PortA to output mode movlw 00h movwf TRISB ; set PortB to output mode movlw 00h movwf TRISC ; set PortC to output mode BANK0 ; *************Sending Data to LCD*************** ;variable counter = 1 ;call Loop_Long call Delay ; Power Up the LCD controller call Init ; Initialize the LCD Controller movlw 05h ; Print 'P' movwf PORTC call Data_control movlw 00h movwf PORTC call Data_control movlw 04h ; Print 'A' movwf PORTC call Data_control movlw 01h movwf PORTC call Data_control movlw 05h ; Print 'P' movwf PORTC call Data_control movlw 00h movwf PORTC call Data_control call Sc_Clear ; Clear the LCD Screen call Loop ; ************** Command Function ************* Command_control movlw 00h movwf PORTA movlw 01h movwf PORTB call Delay2 movlw 00h movwf PORTB return ; ************** Data Function **************** Data_control movlw 02h movwf PORTA ; use RB0,RB1 for RS,R/W movlw 01h movwf PORTB ; Data of PORTC move to LCD call Delay2 ; Delay of 1.5 mS movlw 00h movwf PORTB movlw 00h movwf PORTA return ;************** Initialise Function ************ Init movlw 03h movwf PORTC call Command_control movlw 03h movwf PORTC call Command_control movlw 03h movwf PORTC call Command_control movlw 02h movwf PORTC ; Function Set for 4 bits, 2 lines, 5x7 dots call Command_control call Delay movlw 02h ; Entry mode : 4 bits, 2 lines movwf PORTC call Command_control call Delay1 movlw 08h movwf PORTC call Command_control call Delay1 movlw 00h ; Enable Display / Cursor movwf PORTC call Command_control call Delay1 movlw 08h movwf PORTC call Command_control call Delay1 movlw 00h ; Cursor Blink movwf PORTC call Command_control call Delay1 movlw 0Eh movwf PORTC call Command_control call Delay1 return ;************* Delay subroutine :5mS ***************************** Delay loop1 decfsz COUNT1,1 ; decrease 1 from 255 goto loop1 loop2 decfsz COUNT2,1 ; decrease 1 from 255 goto loop2 loop3 decfsz COUNT3,1 ; decrease 1 from 255 goto loop3 loop4 decfsz COUNT4,1 ; decrease 1 from 255 goto loop4 loop5 decfsz COUNT5,1 ; decrease 1 from 255 goto loop5 loop6 decfsz COUNT6,1 ; decrease 1 from 255 goto loop6 loop7 decfsz COUNT7,1 ; decrease 1 from 255 goto loop7 return ;************* Delay subroutine :1.5mS **************** Delay1 loop9 decfsz COUNT1,1 ; decrease 1 from 255 goto loop9 loop10 decfsz COUNT2,1 ; decrease 1 from 255 goto loop10 return ;************* Delay Subroutine : 350 uS *************** Delay2 movlw 7Dh movwf COUNT1 loop8 decfsz COUNT1,1 ; decrease 1 from 255 goto loop8 return ; *********** Hold the Program ****************** Loop loop11 decfsz COUNT1,1 ; decrease 1 from 255 goto loop11 incfsz COUNT1,1 ; increase 1 to 1 goto loop11 return ; *********** Clear the screen ****************** Sc_Clear movlw 00h movwf PORTC call Command_control call Delay1 movlw 01h movwf PORTC call Command_control call Delay1 return end ; end of the program
