how to keep RTC data update
Sun May 08 2011, 11:58 pm
You have enabled the interrupt thats fine.. but what kind of RTC interrupt is enabled that is unclear. you should select when you want RTC interrupt. there must be some condition when RTC interrupt is happening.
and are you getting "counter incrementing" continuously on terminal??
Wed May 11 2011, 07:55 pm
yes i've activated 1 second interrupt and for every interrupt i am getting "counter incrementing"
Fri May 13 2011, 08:37 pm
i am using LPC2368 having built in RTC.
If i activate my RTC it runs properly.same time other program stops
thanks for the reply
Sat May 14 2011, 04:24 pm
@ bikashh
have a look on these pages
http://www.keil.com/forum/9493/
http://www.embeddedrelated.com/groups/lpc2000/show/51676.php
here is a c sample code
Tue May 17 2011, 04:15 pm
yes i solved the problem. in the initialization i only had to clear ILR.
thanks a lot for your help
