how to interface mobile with 8051 microcontroller....
Discussion in "GSM and CDMA Discussion" started by horror raju Feb 5, 2008.
Sat Dec 20 2008, 11:32 am
can i use Nokia6020 for sending/receiving AT commands from u-controller ....does it support any com port interface cable...????....plz name some of cheapest mobiles from nokia/samsung...etc...thts supports com port interface....thnx....
Sat Dec 20 2008, 05:49 pm
The 6020 uses a common pop-port, comm's is via USB.
http://pinouts.ru/CellularPhones-Nokia/nokia_pop_pinout.shtml
I would recommend an old ericsson. I'm using a T10 and T18s. Check out pinouts.ru for connections and comm's.
Cheers.
Cheers.
Sun Dec 21 2008, 03:51 pm
go for sony erricsson's T610 or any phone listed on this page..
http://pinouts.ru/CellularPhones-P-W/erics_t28_pinout.shtml
Mon Dec 22 2008, 06:31 am
i chose some of d following mentioned mobile 4m dis site..do day obey d AT commands.. ineed 2 confirm it please....Nokia 1110, 6030, 6060,Nokia 3100, 6100, 6108, 6235, 3310, 3315, 3330, 3350, 3390, 3410,Sendo M550, Thomson TN710,Nokia 1255
Sun Apr 05 2009, 12:02 am
Execuse me but this cicruit connect the mobile directly :
here : http://www.serasidis.gr/circuits/smscontrol/smscontroller.htm
and I'm want to do the similar but with different mobile ..
does that this make difference ?
Sun Apr 05 2009, 11:18 pm
computer eng. the link you posted use phone with internal modem and which is most recommended for embedded projects. they have simple and direct interface to controllers, easy to use AT Command set makes it easy to use them in projects.
whereas phones like 3310, 3315 etc, uses FBUS a typical protocol from nokia. it hard to use and need lot of time to debug, you cannot send messages on runtime easily as message has to packed first in PDU format and then transmitted to phone in a specific frame format at high baud of 115200.
try if you can find some simple phone like sony erricson T610 etc.
Thu Mar 31 2011, 11:01 pm
wat about NOKIA-1110..that supports AT commands..?
(Ajay sry,fr being repetitive,bt GSM modem and other mobile handsets mntioned are not available..thts why askng fr ths particular handset...!!)
plz help....
plz help....
