Discussion in "Project Doubts" started by    pratikshinde    Jul 19, 2012.
Sat Mar 16 2013, 10:37 am
#31
thank you pratik and ExperimenterUK for your response. i also feel that the hardware is problem But i chacked all connection with 16x2 LCD and VCC,GND. I have checked adjusting VEE for contrast but no effect.I have connected Pull-UP resistor to P0.4-P0.7 only. dose it effect?
Sat Mar 16 2013, 10:40 am
#32
I will also check delay function hope it will work
Sat Mar 16 2013, 01:19 pm
#33
delay function for LCD work well
Sat Mar 16 2013, 05:40 pm
#34
Is it working or not? I am confused. Coz I see everything is fine on proteus.
Sat Mar 16 2013, 05:50 pm
#35
It is not working bro.
Sun Mar 17 2013, 11:59 pm
#36
LCD code is not working Ajay.Can you please suggest me proper Crystal value and capacitor? and also reset circuit for AT89C51
Mon Mar 18 2013, 03:50 am
#37
taher
The crystal circuit in your diagram looks okay.
Reset should normally be low, try this arrangement.
Mon Mar 18 2013, 10:24 am
#38
Please follow the circuit given by ExperimenterUK. You can also post your actual circuit design if in case you are still facing any problem.
Mon Mar 18 2013, 11:19 am
#39
thanks for your reply AJAY and ExperimenterUK. i will try this and hope i will succeed.
Tue Mar 19 2013, 12:07 pm
#40
@ExperimenterUK
Still not working. I just fed up!!!.
need help...:(
Dulcehet
Fri May 10 2024, 04:22 pm
ElvasKl
Fri May 10 2024, 04:54 am
RonaldNak
Thu May 09 2024, 07:45 pm
Jamescon
Thu May 09 2024, 12:52 pm
RobertSkats
Thu May 09 2024, 10:23 am
hvCar
Thu May 09 2024, 05:53 am
DJGlido
Wed May 08 2024, 09:28 pm
migCar
Wed May 08 2024, 04:48 pm
