zero crossing signal problem
Mon Oct 15 2012, 12:06 pm
@ExperimenterUK,
In your circuit what is the opto-coupler IC number ? In other words, can you tell me the calculation how you have arrived at 15K 2W value ?
Mon Oct 15 2012, 12:36 pm
i have used moc3041...wat calculation u talkin abt sowie i dnt get u..?
Mon Oct 15 2012, 01:10 pm
i have made the exact circuit which is given in date datedheet of moc3041..chck it out...n i jst used 1/2w resistance for value 360ohm n 330ohms
Mon Oct 15 2012, 04:46 pm
My dear lucky6772, I am talking about ExperimenterUK's circuit which he had posted.Just see his circuit and tell me something about the 15k, 2w resistor.
Mon Oct 15 2012, 11:09 pm
@ExperimenterUK,
In your circuit what is the opto-coupler IC number ?Amit Kumar Das
Well I'd use an H11B1, because they are very sensitive,
......and I have several
You could use many types as long as you supply enough current to turn them on at the right time.
can you tell me the calculation how you have arrived at 15K 2W value ?Amit Kumar Das
15k is just a reasonable value.
It passes enough current to turn on many onto-couplers early in the cycle,
but not so much as to dissipate too much power.
A 15k resistor across 220 volts dissipates 3.22 watts.
This is only half wave so it dissipates 1.6 watts.
Some experimentation might be needed.
Tue Oct 16 2012, 01:22 am
void isr(void) interrupt 0
delay(8);
moc=0; // bulb on
delay_100us():
moc=1; // triac is on now, switch off control
not working at all....the bulb stop glowin and remain off.///
delay(8);
moc=0; // bulb on
delay_100us():
Tue Oct 16 2012, 03:35 am
Try ...
Can you post your circuit diagram.
void isr(void) interrupt 0 { delay(2); //also try values of 1 to 8 moc=0; // bulb on delay_100us(): moc=1; // triac is on now, switch off control }
Tue Oct 16 2012, 03:38 am
#include <REG2051.H>
int i,j,a;
sbit up=P3^4;
sbit down=P3^5;
sbit moc=P3^7;
void delay();
/*void delay(int x)
for(i=0;i<100;i++)
for(j=0;j<x;j++)
void delay1(int d)
int k;
TL0=0x17;
TH0=0xFC;
TR0=1;
for(k=0;k<d;k++) //will produce dx1ms of delay
while(TF0==0)
TF0=0;
TL0=0x17;
TH0=0xfc;
TR0=0;
delay1(8);
moc=0; // bulb on
delay1(2);
TMOD=0x01;
//P3=0xff;
//IT0 = 1; // Configure interrupt 0 for falling edge on /INT0 (P3.2)
EX0 = 1; // Enable EX0 Interrupt
EA = 1; // Enable Global Interrupt Flag
P1=0xA5;
int i,j,a;
sbit up=P3^4;
sbit down=P3^5;
sbit moc=P3^7;
void delay();
/*void delay(int x)
for(i=0;i<100;i++)
for(j=0;j<x;j++)
void delay1(int d)
int k;
TL0=0x17;
TH0=0xFC;
TR0=1;
while(TF0==0)
TF0=0;
TL0=0x17;
TH0=0xfc;
TR0=0;
delay1(8);
moc=0; // bulb on
delay1(2);
TMOD=0x01;
//P3=0xff;
P1=0xA5;
[ Edited Tue Oct 16 2012, 03:39 am ]
Tue Oct 16 2012, 03:42 am
void delay1(int d) { int k; TL0=0x17; TH0=0xFC; TR0=1; for(k=0;k<d;k++) //will produce dx1ms of delay { while(TF0==0) TF0=0; TL0=0x17; TH0=0xfc; } TR0=0; }
s per my calculation the value "fc17" should produce 1milisecond of delay but it is not generting while i cheked on keil debugger its producing around 66ms. now tell me where i am wrong.
