haserver implementation issue
Discussion in "Project Doubts" started by dhanushka888 Dec 12, 2012.
Fri Dec 21 2012, 08:05 pm
@ExperimenterUK & coolmirza143
i was busy last days due to our exam period.. thank you both.. i will try this.. thanks again
[ Edited Fri Dec 21 2012, 08:12 pm ]
Sat Dec 22 2012, 10:09 pm
I replaced crystel as you both said and now its work fine!!!
i want to know another thing,
i used one pc and one laptop, haserver hrdware connect with pc through serial cable..
pc connect to the internet using usb dongle..
laptop also connect to the internet through another usb dongle and i tried to access haserver using that laptop's telnet client.
i used both my pc's private IP(ipconfig shown address/ that is dynamic) and public IP which i found from internet(using "show my IP" at google)
but i couldn't connect with pc's haserver..
what is the problem.??
Sat Dec 22 2012, 10:52 pm
@ dhanushka888
as i think this project will work on a LAN network
as in your case the pc and laptop both are connected with different usb dongle
that is why you are not able to connect
it is my guess
it is my guess
Sun Dec 23 2012, 02:47 am
Make sure all firewall software is disabled on the PC and laptop.
This is the one to use.
What it your internal address ?
i used both my pc's private IP(ipconfig shown address/ that is dynamic)dhanushka888
[ Edited Sun Dec 23 2012, 02:51 am ]
Sun Dec 23 2012, 11:12 am
@ExperimenterUK
i disabled firewalls..
at this time my IP address is 10.225.90.133 and default gateway is 10.225.90.134..
these are in private range..?? that address assign to me by mobitel(my isp).
so how can i access that computer using telnet over internet..
Mon Dec 24 2012, 12:15 am
Being Network Engineer i can help you in this regard..... but sincerely its not an e z thing to deal with!!
you need a Public IP this time you are under a private host/ ISP.... if you wanna use this hardware in this scenario then you must have access to router of your ISP again impossible so in these circumstances you are not able to communicate with your hardware with any front or back door!!!
Mon Dec 24 2012, 04:33 am
The problem is that your two USB dongles are actually part of a LAN owned by the mobile phone network.
I'm afraid computers in the outside world cannot "call" your PC or laptop.
Nor can your PC or laptop call each other
You need a "hardwired" internet connection such as broadband or even a dial up connection.
It has been a while since I used a dial up connection, but it should still work.
If anyone knows how to do it, please let us know.
