want ir LONG RANGE ciruit for reflected type ir sensor
Thu Apr 11 2013, 05:55 pm
hey guys i am using tsop 1736 but nw the problem is the out of tsop1736 is not getting low.,.when the IR signal recieves the voltage from 5v to goes to 4v as a result the controller take it as HIGH signal..help me..!
Mon Apr 15 2013, 05:34 pm
Who is sending IR signal? How you are checking voltage levels? if its going to 4v from 5v after IR signal is available. it usually means its working.
Mon Apr 15 2013, 06:36 pm
Similar kind of circuit is used in one of the project on our website. You can take reference from that circuit and try it.
http://www.8051projects.net/download-d119-automatic-room-light-controller-visitor-counter-updated.html
check receiver circuit.
Mon Apr 15 2013, 11:51 pm
hey guys i am using tsop 1736 but nw the problem is the out of tsop1736 is not getting low.,.when the IR signal recieves the voltage from 5v to goes to 4v as a result the controller take it as HIGH signal..help me..!lucky6772
What transmitter are you using ?
You need a continuous signal at the right frequency to get a response.
Tue Apr 23 2013, 03:27 am
the receiver circuit given not working...
Tue Apr 23 2013, 06:05 pm
project is working.. so receiver should also work... So probably your transmitter is at fault then.
Wed Apr 24 2013, 12:42 am
nope transmitter m using is tv remote...it cant b faulty..! m not getting any out change at output of 555timer its alwz remains 5v or high.!
Thu Apr 25 2013, 12:19 pm
Yes the out of tsop is goin low but not so much 5v to 4v. The voltage is drop but not so much
