want ir LONG RANGE ciruit for reflected type ir sensor
Sun Jul 07 2013, 02:06 am
Use different components and a separate power supply
what do you mean by thiis..? shoult i use separate supply for controller n ir..?
Sun Jul 07 2013, 02:21 am
Sir, I understand that P1.0 would give me 38KHz. But in the my code, if you observe, you could see that instead of you using the whole port, i am using only 1 pin and making it toggle for every timer overflow. how does it differ from your code. please let me know.
and i am using 'a' as a counter to check the no. of cycles.
void timer0_isr () interrupt 1
ir= ~ir;
a++;
mahmoud.r like this.
Mon Jul 08 2013, 04:33 am
what do you mean by thiis..? shoult i use separate supply for controller n ir..?lucky6772
One supply for the transmitter, and another for the receiver.
Sir, I understand that P1.0 would give me 38KHz. But in the my code, if you observe, you could see that instead of you using the whole port, i am using only 1 pin and making it toggle for every timer overflow. how does it differ from your code. please let me know.lucky6772
I don't know what you are asking here.
I posted some code,
you made changes.....
You must know how your code differs from my original.
Mon Jul 15 2013, 12:03 am
nope still no progress..! i ask someone he said ur signal is getting attenuated may b..! or the transistor is very slow,,as per code swtiching should b fast so make ur circuit fast switching compatible so now. looking for that kinda circuit..to drive my led..!
Wed Jul 17 2013, 12:09 pm
Did you look at these websites I gave last time:
http://www.boondog.com/tutorials/lrir/mc145026.htm
http://pcbheaven.com/circuitpages/Long_Range_IR_Beam_Break_Detector/?p=0
Fri Jul 26 2013, 01:04 am
can you help me with circuit diagram..using fet to drive ir led..??lucky6772
Try this ...
http://www.talkingelectronics.com/projects/MOSFET/MOSFET.html
Replace the motor with your LED and a limiting resistor.
[ Edited Fri Jul 26 2013, 01:05 am ]
