want ir LONG RANGE ciruit for reflected type ir sensor
Sat Jul 27 2013, 06:59 pm
now i am getting good range wen i place the tsop1738 reciver and ir led transmitter face to face abt 3ft...! but wen i place them both together to use them reflected beam type..i.e (when i place hand in front of ir led it reflect back the signal to tsop recicevr) i am not getting range its only abt 10cm..!
nw i am using this circuit..!
[ Edited Sat Jul 27 2013, 07:01 pm ]
Sat Jul 27 2013, 07:03 pm
ajay_bhargav like this.
Sat Jul 27 2013, 08:16 pm
#include <REG2051.H> sbit ir=P1^7; sbit motor=P1^6; sbit motor1=P1^4; sbit sense=P3^3; int a,b,c,d,e,j,k,l,m,i,n,flag; void delay_ms (unsigned int count) // @ 11.0592 MHz { unsigned int i; while(count) { i = 115; while(i> 0) i--; count--; } } void timer0_isr () interrupt 1 { if(n<=99) // 600Us ON-OFF Burst for 100 cycles(60ms) { if(n%2!=0) { TH0=0xFD; // 600Us OFF TL0=0xD6; TR1=0; ir=0; n++; } else { TH0=0xFD; // 600Us ON TL0=0xD6; TR1=1; ir=1; n++; } } else // IR completely off for 60ms { TR1=0; TH0=0x27; //60ms OFF Period TL0=0xFB; ir=0; n=0; } } void timer1_isr () interrupt 3 { ir = ~ir; } void isr(void) interrupt 2 { e=1; if(flag==0) { motor=1; delay_ms(3000); motor=0; a=1; flag=flag+1; } } void main () { a=0; flag=0; e=0; n=0; P1=0xff; TMOD=0X21; TH1=0xf4;//38Khz Timer TH0=0xFD;//600Us TL0=0xD6; IE=0x8f; //0x8f; IT1=0; // Configure interrupt 0 for falling edge on /INT1 (P3.2) TR1=1; TR0=1; while(1) { if(a==1) { e=e-1; if(e<0) { TR0=0; motor1=1; delay_ms(7000); motor1=0; TR0= 1; TR1=1; a=0; flag=0; e=0; } } } }
