Discussion in "ARM Development" started by    diana1234    Jul 8, 2014.
Tue Jul 15 2014, 11:54 pm
@ExperimenterUK
Thanks sir for your reply
here i dont want to make a charger, its charger is already at with me. but i want to check the status of the battery (low, medium, when to connect the charger etc.) so that i can show it to my LCD display and for that purpuse i have to add some circuitary to my circuit.
Circuit for get aware the status of battery, not for charging the battery.
Please reply
Thanks in advance
[ Edited Wed Jul 16 2014, 12:58 pm ]
Thu Jul 17 2014, 10:06 am
I find it hard to get battery status by just looking at the voltage level, coz there is a very less variation in voltage and it drops suddenly when its almost fully discharged. You might need to use an external chip which can measure state of charge of the battery. Also if you're still planning to do it without a battery manager then you first have to understand your battery charactistics as they tend to change with temperature too.
Can you post a link to battery information from manufacturer and part number of battery?
Fri Jul 18 2014, 12:43 pm
Thank you ajay sir
The link of the manufecturer is : http://bharatpowersolution.com/
and the part number of the battery is : BPS.5S1P.
The datasheet is also attached here.
Mon Jul 21 2014, 10:40 am
Discarge cut-off voltage is 15v, for experiment purpose you can read and display battery voltage while in operation and see if it decreasing and till how long it can go before it dies. That will give you range or maximum and minimum sample value for which you need to monitor your battery state.
