Tue Mar 11 2008, 11:54 pm
Didou please create a new thread. Otherwise this will confuse users reading this thread. Your topic of discussion is different from this one.
Sat Aug 09 2008, 05:57 pm
Hi Everyone.
I am doing a project using AT Command. I am using Nokia 6680 set. I can communicate with my 6680 via USB by Hyperterminal or Proteus VSM. But I cant communicate via Serial port. I think there must be an initializaig command for enable FBUS. But I dont know that. thats why i cant make communication via Serial port.PLZZZ help me out.
10x.
.::sakibnaz::.
Tags proteus vsmnokia 6680hyperterminalserial portnokia
Wed Aug 27 2008, 01:56 pm
i am trying to do project on gsm based switch controller. i have all the information. i stuck some where in coding. please can u send me code for this in 8051.
Fri Aug 29 2008, 12:25 am
Hi ajay, Pls help in my project Sms transmission with Nokia3310 and microcontroller.
Its urgent pls help
i have already having a thread on it but i am not getting the answers.
Sat Nov 29 2008, 11:04 pm
I have a setup of phone -> MCU but before that i'm trying to make the PC work with the phone via a terminal software.
NOw i have an FBUS cable and FBUS phone(S) (1100, 2626, . ) so mobius works, i can read my contacts and sms with mobius so means datacable is okay. But when i try to send the commands in a terminal window, the following occurs.
1. I send 'U' 0x55 128 times. No response.
2. I send the frame for getting h/w s/w version.. no response
3. I send the frame for getting h/ws/w version .. no response
3. I send the frame for getting h/ws/w version .. I get the h/w s/w version in my terminal window 3 times! starting from the ACKNOWLEDGe frame..
What could the problem be??
Sat Nov 29 2008, 11:07 pm
I've used like 5 or 6 different terminal softwares and all give the same problem, i think its something with the Acknowledge signal or something and i think abicash had a similar problem , can someone please help me solve it?
Fri Dec 19 2008, 09:59 am
Currently I am able to send and receive SMS using FBUS on Nokia 3310 using AT89S52. I am now trying to add support for Nokia 6510. My problem now is that Nokia 6510 will not send the received sms through Fbus once a new SMS is received. So that means the only way to get sms is by polling periodically.
What is the fbus frame that i should send to get new unread sms from the phone ?
I tried using gnokii using --getsms IN 1 but i couldn't understand which part of the frame is for getting new sms.
Wed Dec 24 2008, 10:22 pm
hi ntung,
Congrats !!! u have got your 3310 sms controller ready ...
i'm also working on the same type of a project... the problem i face is ..... my mobile is not replying to the "get h/w s/f version command" . Before sendin this command, i sycn'ed the mobile to my pc by sending 'U' 128 times .. but no use .. can u help help me out in this regard .... i would be very happy if u could list me the sequence of events that needs to be done....
plzzz
bye
Thu Dec 25 2008, 03:02 am
is your circuit working? do make sure of it first.
 senchen like this.
Sat Dec 27 2008, 08:31 pm
hi ajay,
the problem was in my program .. i have fixed it ... now i'm able to get the hw sw version from the phone ... but a new problem is bothering me ... in the 3310 data cable both the fbus rx and tx pins are shorted because of which the data i send is returned back to the pc ... this makes the programming a bit complicated (i have to drop the data sent by the pc before reading the actual data sent by the phone)... can i separate these two pins to avoid this ?? ....
thanks
bye
RobertGug
Tue Jun 18 2024, 04:38 pm
Jasonabepe
Tue Jun 18 2024, 04:24 pm
Thomcyday
Tue Jun 18 2024, 08:38 am
WalterWib
Tue Jun 18 2024, 05:44 am
SialisshopWat
Mon Jun 17 2024, 09:22 pm
Thomasraima
Mon Jun 17 2024, 07:17 pm
EriksaLaf
Mon Jun 17 2024, 03:13 pm
Anthonyjinee
Mon Jun 17 2024, 06:23 am
