Sun Dec 28 2008, 03:29 am
rx tx shorted? strange.. did u check on PC for this? are u sure everything is getting echoed? because if that is the case, phone should not work at all. i suggest u to check again.
make sure echo is turned off in hyper terminal or whatever tool you are using.
 senchen like this.
Sun Dec 28 2008, 01:10 pm
ya .. they are shorted and the data i send is echoed back (and also the phone replies to the request(get hardware software version) i send ).. i use 'serial port monitor' for monitoring the serial port ... i think i can show u the log file of the serial port activities so that u can get a clear idea of wat actually happens... i am sending it as a private message to you .... pls check your inbox .. i'm also attaching the wiring of the cable along with that mail ...
i would like to tell u one more thing ... with the same cable, logo manager works very well .. i can send sms and can also read the contacts from the phone thru the logo manager with the same cable....
bye
thanks
[ Edited Sun Dec 28 2008, 01:39 pm ]
Sun Dec 28 2008, 08:04 pm
RX and TX pin should not be shorted. I build my on cable based on the schematic from http://www.panuworld.net/nuukiaworld/hardware/cables/fbus.htm
The software I use for testing is Eltima Serial Port Monitor
 senchen like this.
Sun Dec 28 2008, 09:19 pm
hi ntung,
ya i too have seen that site ...the schematics are quite clear there ....but will that work for 3310 model ? have u tested it on 3310 ..?
logo manager works very well with the cable i'm using now ...
thats y i can't confidently conclude that the cable is wrongly wired ...
bye
thanks
Sun Dec 28 2008, 10:44 pm
It works on my Nokia 3310. If it works on logo manager, then the cable should be fine.
Mon Dec 29 2008, 12:30 pm
Some Nokia's used M-bus ,some F-bus and some both.
M-bus transmits and receives on the same pin.
Some cables are switchable(and some badly made). Just a thought
Fri Jan 02 2009, 10:19 pm
can anyone help me how get the message center number through fbus protocol ... Any specific Commands ??
Sat Jan 03 2009, 03:24 am
check gnokii.org for fbus specification for nokia 3310
by the way, why you need Message center num?
 senchen like this.
Sat Jan 03 2009, 09:46 am
I want to program the micro controller in a such a way that the mesage center number is read automatically from the phone before the message is framed and sent ... (user dont have 2 enter it manually each time the service provider is changed)
By the way, did u find out anything about the RX TX short ??
Thanks
bye
[ Edited Sat Jan 03 2009, 09:48 am ]
Sun Jan 04 2009, 01:59 am
must be a problem in wire i guess.. you can open the backpanel of datacable to check the electronics behind it and find out why its showing short.
regarding message center, visit this page and search for "Get SMS Center" in that page you will get the packet format.
http://cvs.savannah.gnu.org/viewvc/gnokii/Docs/protocol/nk6110.txt?root=gnokii&view=markup
 senchen like this.
MnoioCoove
Tue May 21 2024, 02:06 am
PedroDug
Sun May 19 2024, 05:39 pm
JewelAmuck
Sun May 19 2024, 03:06 pm
Minniemus
Sun May 19 2024, 07:39 am
Andyhet
Sat May 18 2024, 07:28 am
BrettTibre
Fri May 17 2024, 06:14 pm
Gordonfax
Fri May 17 2024, 10:28 am
Davidspils
Fri May 17 2024, 10:19 am
