Discussion in "General help Guidance and Discussion" started by    shyam    Mar 27, 2008.
Fri Mar 28 2008, 11:01 pm
you must click on thanks button
Ajay
Done dude......now Amit's turn
[ Edited Fri Mar 28 2008, 11:01 pm ]
Fri Mar 28 2008, 11:37 pm
He he
Sun Mar 30 2008, 01:31 pm
very good info in the forum. another interesting application (which uses the exact inverse principle)of the above method is the oversampling technique used to increase the resolution of the ADC. this is well explained in AVR application note AVR121. It uses oversampling to increase the resolution for its inbuilt adc from 10 bit to 16 bit by introducing a fixed noise source. It could well be used in slower systems like temperature but the ADC conversion should be really fast.check this file out
http://www.atmel.com/dyn/resources/prod_documents/doc8003.pdf
FrankTrelm
Tue May 14 2024, 10:39 am
BillyTum
Tue May 14 2024, 09:08 am
Loganbag
Tue May 14 2024, 04:05 am
MichaelMog
Tue May 14 2024, 03:58 am
ThomasGaxaW
Mon May 13 2024, 05:33 pm
RobertInfup
Mon May 13 2024, 04:28 pm
Joshuatem
Mon May 13 2024, 08:30 am
RaymondPex
Mon May 13 2024, 03:24 am
