8051 based project That can save up to 60 codes with max of 6 combination of numbers
Tue Nov 23 2010, 11:18 am
i can help you regarding LCD..... first make logic of wat u wanna do and write your code
Tue Nov 23 2010, 11:24 am
hi onyot.. this code is for displaying numbers on the 7 segment in every key pressed on the keypad.. get some idea here.. the keypad is 4x3 matrix
#include <REG51.h> #define KEYPAD P1 #define display P3 void DelayMs(unsigned int) ; unsigned char keypad[4][3]= { 1 , 2 , 3 , 4 , 5 , 6 , 7 , 8 , 9 , 15 , 0 , 15 } ; void main() { unsigned char colloc,rowloc; while(1) { do { KEYPAD=0xF0; colloc=KEYPAD & 0xF0; } while(colloc ==0xF0); // if any key pressed DelayMs(1); // some delay do { colloc=KEYPAD; colloc &=0xF0; }while(colloc==0xF0); // to verify is really key pressed KEYPAD=0xFE; colloc=KEYPAD & 0xF0; if(colloc !=0xF0) { rowloc=0; goto next; } KEYPAD=0xFD; colloc=KEYPAD & 0xF0; if(colloc !=0xF0) { rowloc=1; goto next; } KEYPAD=0xFB; colloc=KEYPAD & 0xF0; if(colloc !=0xF0) { rowloc=2; goto next; } KEYPAD=0xF7; colloc=KEYPAD & 0xF0; rowloc=3; goto next; next: if (colloc==0xE0) display=(keypad[rowloc][0]); else if(colloc==0xD0) display=(keypad[rowloc][1]); else display=(keypad[rowloc][2]); } } //--------------------------------------- // Delay mS function //--------------------------------------- void DelayMs(unsigned int count) { // mSec Delay 11.0592 Mhz unsigned int i; while(count) { i = 115; while(i> 0) i--; count--; } }
Tue Nov 23 2010, 11:39 am
Mr. Romel Emperado, can I have the final code of the password program that you have?
Tue Nov 23 2010, 11:43 am
#include <REG51.h> #define display P3 #define KEYPAD P1 sbit doorclose = P1^7; sbit correct = P3^5; sbit wrong= P3^4; sbit key = P3^7; void DelayMs(unsigned int); void save (unsigned char); void compare (void); unsigned char keypad[4][3]= { '1', '2', '3', '4', '5', '6', '7', '8', '9', '*', '0', '#'}; unsigned char displayb[4][3]= { 1 , 2 , 3 , 4 , 5 , 6 , 7 , 8 , 9 , 0, 0 , 0}; unsigned char code password[5]= "12345"; unsigned char user[30]; //user is allowed to press 30 keys without entering unsigned char q,a=0,z=0; char t=1; bit true; char d; void main(void) { unsigned char colloc,rowloc; while(1) { do { KEYPAD=0xF0; colloc=KEYPAD & 0xF0; } while(colloc ==0xF0); // if any key pressed DelayMs(1); // some delay do { colloc=KEYPAD; colloc &=0xF0; }while(colloc==0xF0); // to verify is really key pressed KEYPAD=0xFE; colloc=KEYPAD & 0xF0; if(colloc !=0xF0) { rowloc=0; goto next; } KEYPAD=0xFD; colloc=KEYPAD & 0xF0; if(colloc !=0xF0) { rowloc=1; goto next; } KEYPAD=0xFB; colloc=KEYPAD & 0xF0; if(colloc !=0xF0) { rowloc=2; goto next; } KEYPAD=0xF7; colloc=KEYPAD & 0xF0; rowloc=3; goto next; next: if (colloc==0xE0) { key=0; // verifying that key is pressed DelayMs(145); key=1; display=((display & 0xf0) | (displayb[rowloc][0])); // display to 7 seg save(keypad[rowloc][0]); } else if(colloc==0xD0) { key=0; // verifying that key is pressed DelayMs(145); key=1; display=((display & 0xf0) | (displayb[rowloc][1])); save(keypad[rowloc][1]); } else if(colloc==0xb0) { key=0; // verifying that key is pressed DelayMs(145); key=1; display=((display & 0xf0) | (displayb[rowloc][2])); save(keypad[rowloc][2]); } DelayMs(100); // here this delay is important if this is less than 100ms then // controller understand 1 key as press 2 or 3 times becoz that //is fast as compaer o our pressing if u want to remove delay from here // then increse the above 1ms to 100 ms } } void save (unsigned char c) { if(c=='*') { if(a!=0) a--; return; } if(a==5 && c=='#') { a=0; compare(); if(t==1) { if(true==1) // if match ok { DelayMs(800); correct=0; t=2; for(d=0; d<7; d++) // on and after 10 sec off nw keypad can't get data DelayMs(1000); // max delay u can get is DelayMs(65535) otherwise need looping for big delay correct=1; z=0; a=0; // start agian from 0 location of array } else if(true==0) goto error; } else if(t==2) { DelayMs(800); doorclose=0; t=1; for(d=0; d<5; d++) DelayMs(1000); doorclose=1; } } else if((a> 5 && c=='#') || (a<5 && c=='#')) { error: for(q=0; q<5; q++) { wrong=0; DelayMs(420); wrong=1; DelayMs(420); a=0; } z=z+1; if(z==4) { for(q=0; q<10; q++) { wrong=0; DelayMs(20000); wrong=1; z=0; DelayMs(420); } } a=0; } else { user[a]=c; a++; if(a==30) // if the user press 31 keys without entering it will automatically indicate an error { display=((display & 0xf0) | (displayb[3][1])); //brings a zero display on the seven segment goto error; //redirect to error code } } } //end of save void compare (void) { unsigned char b; for(b=0;b<5;b++) { if(user[b]==password[b]) true=1; else { true=0; break; } } } //--------------------------------------- // Delay mS function //--------------------------------------- void DelayMs(unsigned int count) { // mSec Delay 11.0592 Mhz unsigned int i; while(count) { i = 115; while(i> 0) i--; count--; } }
Can you tell me, how is it work? I understand slightly but I don't know if it is correct.. So I need YOur help guys!
[ Edited Tue Nov 23 2010, 11:46 am ]
Tue Nov 23 2010, 11:44 am
onyote try making your own code you have much time to do this.......here are many professionals who will help and guide you
Tue Nov 23 2010, 11:51 am
I don't know if I have that much time because as of now, I am here in an industrial plant having my on-the-job training, then, the work is very tiring.
Okay, I'll make a program and I will post it, maybe tomorrow...
Tue Nov 23 2010, 11:53 am
Mr. Romel Emperado, can I have the final code of the password program that you have?onyot.josephian
hi onyot.. take it as your guide..and i hate to say bye to u guys i have a class... see u later
onyot, where and what plant is that? is this your project or they require u this?
mirza,, kaon ta ug tae.. hehehe se me in FB lol
[ Edited Tue Nov 23 2010, 11:57 am ]
onyot.josephian like this.
Tue Nov 23 2010, 12:02 pm
who knows how to make a keypad? just a simple keypad...onyot.josephian
there are many keypad schematic in www.google.com choose keypad that suite to your need..
