Doubt regarding the LED driving capability of microcontroller
Thu Aug 23 2007, 03:52 pm
i cant see the attached schematic :S try using www.imageshack.us
get the direct link to image and post it here in [ img ] and [ /img ] tags
*remove spaces!! from the tags.
Thu Aug 23 2007, 04:15 pm
http://img120.imageshack.us/img120/6200/schematicslo5.jpg
and my coding is
#include<REG51.H>
sbit UD = P3^2;
sbit TD = P3^3;
unsigned int count = 0x00, FMS = 0x00, units, tens;
void display(void);
void main(void)
unsigned int a[10]={0x7E,0x30,0x6D,0x79,0x33,0x5B,0x5F,0x70,0x7F,0x7B};
TMOD = 0x01;TF0 =0; TR0 = 0;
IE = 0x82;
count = 30;
while(count != 0){
count--;
display();
TL0 = 0xFD; TH0 = 0x4B;
TR0 = 1;
while(FMS<20);
TR0 = 0;
TF0 = 0;
FMS = 0x00;
void display(void)
units = count/10;
tens = count%10;
UD=1; TD=0;
P1=a[units];
UD=0; TD=1;
P1=a[tens];
void Timer0(void)interrupt 1{
TR0=0;
TL0= 0xFD;TH0= 0x4B;
FMS++;
TR0=1;
and my coding is
#include<REG51.H>
sbit UD = P3^2;
sbit TD = P3^3;
void display(void);
void main(void)
IE = 0x82;
count = 30;
while(count != 0){
count--;
display();
TR0 = 1;
while(FMS<20);
TR0 = 0;
TF0 = 0;
FMS = 0x00;
void display(void)
units = count/10;
tens = count%10;
UD=1; TD=0;
P1=a[units];
UD=0; TD=1;
P1=a[tens];
TR0=0;
FMS++;
TR0=1;
Thu Aug 23 2007, 04:18 pm
lookup table was missed
Thu Aug 23 2007, 04:20 pm
Oooh again :mad I hope this it will be visible :blush
Thu Aug 23 2007, 05:00 pm
you are trying to source the current this always cause a problem i know.. try removing Rb 10K SIP and check if the value of Ra is correct.. i mean.. is it enough to drive the transistor properly and source the current..
Thu Aug 23 2007, 05:37 pm
No,I removed the microcontroller from the IC base and I given the 5V to the port 1 pins. And 5V is also given to the P3.2 and P3.3 but one pin at a time. I'm getting the display.
And one more thing if I palce the mc the voltage across the Port 1 pins for logic high is about 0.9V.
I know this is mc current driving capability issue but I don't know how to fix it
Thu Aug 23 2007, 05:52 pm
you should have chosen common anode.. coz its easy for micros to sink the current rather source... try connecting pull ups at port pin that might help you..
