Discussion in "E107 FURL Support" started by    arvin    Sep 3, 2007.
Tue Sep 04 2007, 05:41 pm
well last i meant last in array...
so in e_module.php and SITELINKS.SC file of FURL
$pattern[18] = '/page\.php\?148';
$replacement[18] = 'myname.html';
$patterns[19] = '/page\.php\?([0-9]+)/';
$replacements[19] = 'page$1.html';
Like that.. so you custom renamed URL should come before in array...!!!
and.. is your e107 installed in subfolder?
 tienduhieu like this.
Tue Sep 04 2007, 05:51 pm
yes therefore also my last thread e107 is in sub/sub folder--therfore i dont really know--wher htaccess have to be located
Tue Sep 04 2007, 06:00 pm
well.. then.. you also need to change the RewriteBase from / to /(subfoldername)/
to make the rewrite url work..
and your new urls will be... www.yoursitename.com/subfoldername/index.html
like that..
Tue Sep 04 2007, 06:11 pm
sure know---and i have tried all possible "positions" of htaccess in my folder strucure.
her is "as told above" folder/folder/ e107--files who must be rewrited
i think its htaccess-my prob---driving crazy here---i get success with several settings---but not totally---the folder is the prob---
Tue Sep 04 2007, 06:18 pm
yes i know... i always recommend to install in the root...
but ur problem is not so difficult to solve.. just u don't have any idea what to do..
the thing is.. there is not one thing which is to be done.. .htaccess is really a hectic stuff to deal with
also its not easy for someone to explain.. coz few things might be very techy..
Tue Sep 04 2007, 06:28 pm
if i would have any idea--i wouldnt ask here ;-)
I am not that person--trying something and if it dont work i ask silly questions.
so you ment---whole script/Plugin dont work in sub sub folder?---AS i told i got it running in some way---without pictures showing---files get fromanother folder as the puicures rries to get (curious)--and you are wright---im am not conform with htaccess---but i know there must ba a possibility
Tue Sep 04 2007, 07:30 pm
well i said its possible.. just you are not using the correct links...
ok.. here is one solution..
can you please give me the link to your site? or you're afraid to share it? or something..?
Tue Sep 04 2007, 09:38 pm
the site url is:
http://www.strandhotel-seehof.de/strandhotelseehof/seo/page.php?148
e107 is in folder /seo/
at present htaccess deleted
and see:
http://www.strandhotel-seehof.de/strandhotelseehof/myname.html ( works--without pictures) and--confused- wrong folder--/seo/ is missing
sorry i am confused
a little help would be great
thx
Tue Sep 04 2007, 11:54 pm
ok.. I understood everything now.. see just giving your URL can solve the whole problem
You have e107 installed in root, and you were just checking if FURL works with your site or not am i right?
I am sure i am
now i want you to do this thing.. do not change anything in your main installation. Remove the content of .htaccess you added.. recently or simply update the .htaccess file with the original .htaccess file that comes with FURL.
now add this thing in the freshly uploaded .htaccess
after the RewriteBase / statement
add
RewriteRule ^myname.html$ /page.php?148
after this.. try the link..
http://www.strandhotel-seehof.de/myname.html
and tell me how it works... waiting for reply..
also this is not going to temper anything with your site ok!
DO NOT INSTALL FURL ON UR MAIN SITE!
 arvintienduhieu like this.
Wed Sep 05 2007, 12:49 pm
hm, thank you very much--works that way--but i am confused a little bit, why it works ;-)
cause furl is installed in a separate testsite two folders deeper.
Only probleme is--leaving admin e107--it redirects me to a page that doesnt have to show up.
But i think i have to change or delete the redirect in index.php.
At present i think about the best way to configure it workable only for the mainsite, with installed furl plugin there.
I think, i leave everything as it is at present, and rewrite at first all my 170 pages. (much work) then i will see--perhaps you can give me tipps to do it finally, working only in Mainsite.
thank you very much.
KevinTab
Sun Apr 28 2024, 05:35 am
Tumergix
Sun Apr 28 2024, 12:59 am
StevenDrulk
Sat Apr 27 2024, 08:47 pm
StephenHauct
Sat Apr 27 2024, 09:38 am
Adamsaf
Sat Apr 27 2024, 07:12 am
