GSM control by 8051
Discussion in "Embedded GSM Development" started by fawadrauf1 Jan 17, 2010.
Fri Jan 22 2010, 04:50 pm
Or if u say that i should not short pin 7 and 8, even then it will not work....
Please help my project submission date is coming nearer...
Thanks...
Thanks...
Sat Jan 23 2010, 11:52 pm
Hey Good NEWs i've interfaced my microcontroller to T610. I succeeded in calling from it.
Now I want to read sms from it. So how come I know How many byte are there?
Lets say the following example:
+CMGL: 2,"REC READ","+923432547856","FAWAD RAUF MO","10/01/23,23:21:23+20"
v
I've only sent 'v' in it. How many bytes are there in this message?
I mean how many times i've to repeat a loop in order to read v from SBUF....
Thanks this forum is really co-operative. Waiting for ur response...
v
Mon Jan 25 2010, 09:40 am
Here you have to search Option...
Whether you want to See SMS in Hex or Text?
from you AT Command set.
Then count the string
Gurpreet Singh
www.embeddedcraft.org
Gurpreet Singh
Mon Jan 25 2010, 06:38 pm
instead of reading all the SMS from memory, fix 1 place in memory lets say '1' where to read SMS from and after reading delete that sms so that new sms comes to same place.
so when reading SMS, you can send command
AT+CMGR=1
you will get only 1 sms at a time.
and its not easy to get how many bytes are there in SMS, coz this kind of chunk will always come from modem when you send read command,
Do share you interfacing circuit with forum coz it may be helpful for others
good luck!
AT+CMGR=1
![](../../images/emotes/FBemote/smile.png)
Mon Jan 25 2010, 09:37 pm
Hi all
i have old Sony erricson j200i mobile can i use it with 8051 microcontroller? for building SMS based device controller project.
Tue Jan 26 2010, 03:47 pm
yes,
Any Mobile Can be Interface with Any microcontroller having UART Interface?
Remember .... you should have Connector detail for that...
Good Luck..
Gurpreet SIngh
Good Luck..
Gurpreet SIngh
