Discussion in "Project Help" started by    don    Aug 7, 2010.
Fri Aug 13 2010, 03:16 am
thank you all.
my last update:
1- i will separate the camera and i will receive its data independently sense i found out that video streaming is programmable with c# and i will have to do id
2- i am still searching about the control part.
3- i will use arduino board to receive the control and move the wheels
okay???!!!
Fri Aug 13 2010, 11:24 pm
sounds good
control part? explain me maybe i can help you.
Sat Aug 14 2010, 02:02 am
i mean how would i control the robot " blietooth, rf , wireless"
any hints??
Sat Aug 14 2010, 02:49 am
you are using wrong terms
bluetooth is RF as well as wireless too hehe.. anyways.
its good to use simple RF modules rather than going for costly bluetooth modules. You can easily find 2.4Ghz RF transceivers or 433Mhz RF transceiver modules in market. they are cheaper and easy to use.
Sun Aug 15 2010, 11:25 pm
but if u use bluetooth then there will be no risk of interference from other transmitter.
we experience this problem in our college tech fest
Tue Sep 14 2010, 07:04 pm
ok.......as a project management idea
i want to try each part of the robo camera car individually.....
and because unfortunately the Arduino chip is going to be late to arrive " verrrrry late"
i will start with c# interface and i will learn hoe to control the transmitter by connecting it to the parallel port " or serial port"
which is easier????
Wed Sep 15 2010, 01:45 am
you mean RF transmitter? check datasheet of module and see what interface is used for it. I believe its gonna be Serial and SPI both you can use any you like. serial is easy than implementing SPI on parallel port.
Tumergix
Sun Apr 28 2024, 12:59 am
StevenDrulk
Sat Apr 27 2024, 08:47 pm
StephenHauct
Sat Apr 27 2024, 09:38 am
Adamsaf
Sat Apr 27 2024, 07:12 am
