Discussion in "8051 Discussion Forum" started by    kirangowle    Jan 11, 2011.
Thu Jan 20 2011, 09:15 am
Hi,
I am wondering if I am using 120vac instead of 220vac. How to I choose the TRIAC, what model I should use?
thanks.
Harrison
hello harri...
Triac usually work on a range of voltage not specific for 220 volt or 120 volt....... see data sheet of triac there you can see it is operating voltage range....
see this attached document it will help you...
Mon Mar 28 2011, 05:25 pm
Hi again,
Does feedback system is necessary for zero cross detector or can i use built in zero cross detector MOC like MOC 3041. for speed variation of FAN.
EriksaLaf
Mon Jun 17 2024, 03:13 pm
Anthonyjinee
Mon Jun 17 2024, 06:23 am
Danieldus
Sun Jun 16 2024, 09:44 pm
Richardrig
Sun Jun 16 2024, 03:05 pm
StevenBrere
Sun Jun 16 2024, 04:23 am
Meganmiz
Sat Jun 15 2024, 09:17 pm
RobertDremn
Sat Jun 15 2024, 02:18 pm
Eugenearilk
Fri Jun 14 2024, 03:16 pm
