PIC16F876 4 bits Display in 16x2 LCD
Discussion in "PIC Microcontroller Discussion" started by pappuneelam May 1, 2011.
Tue May 24 2011, 02:53 pm
did you disable watchdog in your LED blink program and LCD program?
and for LCD, 1K at contrast pin is sufficient. if you still face a problem replace it with a potentiometer for easy adjustment. Incase LCD still does not show up, increase delay everywhere.. try to double them up and see if it works.
Tue May 21 2013, 04:30 pm
hallo mr.ajay....
can u please post the assembly code for displaying anything on the lcd in 4 bit mode....
i'm working with pic 16f913....
i just getting blocks in the led...i know it is the problem with the initialisation...how to initialise the lcd in 4 bit mode...
Wed May 22 2013, 09:43 am
Read about 4-bit LCD mode:
http://www.8051projects.net/lcd-interfacing/lcd-4-bit.php
Thu May 23 2013, 10:11 am
Sorry I do not have ready code for your controller. Share your code, lets see where you're going wrong.
Fri May 24 2013, 03:06 pm
THIS IS MY CODE.....PLEASE GO THROUGH IT
list p=16f913 ; list directive to define processor
#include <p16f913.inc>
org 0x00
STATUS equ 03h
PORTA equ 05h
PORTC equ 07h
TRISA equ 85h
TRISB equ 86h
TRISC equ 87h
bsf STATUS,05
movlw 07h
movwf CMCON0
clrf ANSEL
movlw 0x00
movwf TRISA
movlw 0xfc
movwf TRISC
bcf STATUS,05
COUNT1 equ 50h
COUNT2 equ 51h
R1 equ 22h
R2 equ 23h
R3 equ 24h
R4 equ 25h
temp equ 26h
COUNT3 equ 23h
start
call delay_0
movlw 0x30
call m_init
call delay_1
movlw 0x30
call m_init
call delay_2
movlw 0x30
call m_init
call delay_2
movlw 0x20
call m_init
call delay_2
movlw 0x28
call mask1
movlw 0x08
call mask1
movlw 0x01
call mask1
movlw 0x06
call mask1
movlw 0x0e
call mask1
movlw 0x80
call mask1
;movlw 01h
;call mask1
movlw 'H'
call mask2
movlw 'a'
call mask2
movlw 'i'
call mask2
here goto here
m_init movwf temp
movlw 0xf0
movwf R1
movlw 0x0f
movwf R2
movf temp,w
andwf R1,1
swapf R1,1
andwf R2,1
;swapf R2,1
movf R1,w
call init
movf R2,w
call init
return
mask1 movwf temp
movlw 0xf0
movwf R1
movlw 0x0f
movwf R2
movf temp,w
andwf R1,1
swapf R1,1
andwf R2,1
;swapf R2,1
movf R1,w
call cmd
movf R2,w
call cmd
return
mask2 movwf temp
movlw 0xf0
movwf R3
movlw 0x0f
movwf R4
movf temp,w
andwf R3,1
swapf R3,1
andwf R4,1
;swapf R4,1
movf R3,w
call dat
movf R4,w
call dat
return
init movwf PORTA
bcf PORTC,0
bsf PORTC,1
call delay_0
bcf PORTC,1
; call delay_0
return
cmd
movwf PORTA
bcf PORTC,0
bsf PORTC,1
call delay_0
bcf PORTC,1
return
dat
movwf PORTA
bsf PORTC,0
bsf PORTC,1
call delay_0
bcf PORTC,1
return
delay_0
movlw 0x9F
movwf COUNT1
movlw 0x10
movwf COUNT2
LOOP_0
decfsz COUNT1, 1
decfsz COUNT2, 1
goto LOOP_0
return
;2 cycles
; goto $+1
delay_1
movlw 0xCF
movwf COUNT1
movlw 0x08
movwf COUNT2
loop_1
decfsz COUNT1,1
decfsz COUNT2,1
goto loop_1
return
;2 cycles
; goto $+1
delay_2
movlw 0xC7
movwf COUNT1
movlw 0x01
movwf COUNT2
loop_2
decfsz COUNT1,1
; goto $+2
decfsz COUNT2,1
goto loop_2
return
;2 cycles
;goto $+1
end
org 0x00
STATUS equ 03h
PORTA equ 05h
PORTC equ 07h
TRISA equ 85h
TRISB equ 86h
TRISC equ 87h
bsf STATUS,05
movlw 07h
movwf CMCON0
clrf ANSEL
movlw 0x00
movwf TRISA
movlw 0xfc
movwf TRISC
bcf STATUS,05
COUNT1 equ 50h
COUNT2 equ 51h
R1 equ 22h
R2 equ 23h
R3 equ 24h
R4 equ 25h
temp equ 26h
COUNT3 equ 23h
start
call delay_0
movlw 0x30
call m_init
call delay_1
movlw 0x30
call m_init
call delay_2
movlw 0x30
call m_init
call delay_2
movlw 0x20
call m_init
call delay_2
movlw 0x28
call mask1
movlw 0x08
call mask1
movlw 0x01
call mask1
movlw 0x06
call mask1
movlw 0x0e
call mask1
movlw 0x80
call mask1
;movlw 01h
;call mask1
movlw 'H'
call mask2
movlw 'a'
call mask2
movlw 'i'
call mask2
here goto here
m_init movwf temp
movlw 0xf0
movwf R1
movlw 0x0f
movwf R2
movf temp,w
andwf R1,1
swapf R1,1
andwf R2,1
;swapf R2,1
movf R1,w
call init
movf R2,w
call init
return
mask1 movwf temp
movlw 0xf0
movwf R1
movlw 0x0f
movwf R2
movf temp,w
andwf R1,1
swapf R1,1
andwf R2,1
;swapf R2,1
movf R1,w
call cmd
movf R2,w
call cmd
return
mask2 movwf temp
movlw 0xf0
movwf R3
movlw 0x0f
movwf R4
movf temp,w
andwf R3,1
swapf R3,1
andwf R4,1
;swapf R4,1
movf R3,w
call dat
movf R4,w
call dat
return
init movwf PORTA
bcf PORTC,0
bsf PORTC,1
call delay_0
bcf PORTC,1
; call delay_0
return
cmd
movwf PORTA
bcf PORTC,0
bsf PORTC,1
call delay_0
bcf PORTC,1
return
dat
movwf PORTA
bsf PORTC,0
bsf PORTC,1
call delay_0
bcf PORTC,1
return
delay_0
movlw 0x9F
movwf COUNT1
movlw 0x10
movwf COUNT2
LOOP_0
decfsz COUNT1, 1
decfsz COUNT2, 1
goto LOOP_0
return
;2 cycles
; goto $+1
delay_1
movlw 0xCF
movwf COUNT1
movlw 0x08
movwf COUNT2
loop_1
decfsz COUNT1,1
decfsz COUNT2,1
goto loop_1
return
;2 cycles
; goto $+1
delay_2
movlw 0xC7
movwf COUNT1
movlw 0x01
movwf COUNT2
loop_2
decfsz COUNT1,1
; goto $+2
decfsz COUNT2,1
goto loop_2
return
;2 cycles
;goto $+1
end
[ Edited Fri May 24 2013, 03:07 pm ]
Sat May 25 2013, 04:44 am
This code is a really hard to follow, let alone debug.
I suggest you re-write it.
Don't mix equates and code.
Add lots of comments.
Explain how each subroutine works and the flow of the whole program.
#includeSTATUS equ 03h
PORTA equ 05h
PORTC equ 07h
TRISA equ 85h
TRISB equ 86h
TRISC equ 87h
COUNT1 equ 50h
COUNT2 equ 51h
R1 equ 22h
R2 equ 23h
R3 equ 24h
R4 equ 25h
temp equ 26h
COUNT3 equ 23h //same as R2 ????
org 0x00 //program starts here at 0 (so you can't allow interrupts)
bsf STATUS,05
movlw 07h
movwf CMCON0
clrf ANSEL
movlw 0x00
movwf TRISA
movlw 0xfc
movwf TRISC
bcf STATUS,05
start //???
call delay_0
movlw 0x30
call m_init
#include
PORTA equ 05h
PORTC equ 07h
TRISA equ 85h
TRISB equ 86h
TRISC equ 87h
COUNT1 equ 50h
COUNT2 equ 51h
R1 equ 22h
R2 equ 23h
R3 equ 24h
R4 equ 25h
temp equ 26h
bsf STATUS,05
movlw 07h
movwf CMCON0
clrf ANSEL
movlw 0x00
movwf TRISA
movlw 0xfc
movwf TRISC
bcf STATUS,05
start //???
call delay_0
movlw 0x30
call m_init
[ Edited Sat May 25 2013, 04:46 am ]
Curiou_Som like this.
Mon May 27 2013, 09:49 am
I do not understand why you have to do this:
isn't it defined already in your assembler??
PORTA equ 05h PORTC equ 07h TRISA equ 85h TRISB equ 86h TRISC equ 87h
