Discussion in "Project Doubts" started by    pratikshinde    Jul 19, 2012.
Tue Mar 19 2013, 12:22 pm
#41
@taher
When you give power to circuit , what does display show?
Wed Mar 20 2013, 10:35 am
#42
@pratikshinde It shows blocks thats it........
Wed Mar 20 2013, 11:43 am
#43
did you try to increase delay?
Wed Mar 20 2013, 03:22 pm
#44
no till not, how much delay should i use?
Thu Mar 21 2013, 03:19 pm
#45
Delays are mentioned here:
http://www.8051projects.net/lcd-interfacing/lcd-4-bit.php
Startup delay 20ms, then 10ms, then 1, 1, 1ms. I think your delays are not calibrated.. try to use timer for delays. create a 1ms delay loop and pass ms variable from top.
Fri Mar 22 2013, 10:37 am
#46
hi Ajay
I have connected LED to pin P0^0 but LED was not blinking with 1s delay it was just blinking
Fri Mar 22 2013, 01:00 pm
#47
just give proper delay values it should work fine. Proteus is a simulator it cannot simulate hardware delays sometimes. It only check for proper commands in case of LCD.
RonaldNak
Thu May 09 2024, 07:45 pm
Jamescon
Thu May 09 2024, 12:52 pm
RobertSkats
Thu May 09 2024, 10:23 am
hvCar
Thu May 09 2024, 05:53 am
DJGlido
Wed May 08 2024, 09:28 pm
migCar
Wed May 08 2024, 04:48 pm
TimmyJup
Wed May 08 2024, 12:22 am
Shawnarows
Tue May 07 2024, 10:16 pm
