Discussion in "PIC Microcontroller Discussion" started by    needginer    Mar 2, 2008.
Wed Mar 05 2008, 12:16 am
maybe this help you..
http://ww1.microchip.com/downloads/en/DeviceDoc/31018a.pdf
please write something.. are u using C?
Sat Mar 15 2008, 05:16 pm
hello everybody.. i had try some code in assembly. by the way im using MPLAB to try it. there is an error. when im trying to [build all] 'compile' the code, come out an error "DOS ERROR: FILE NOT FOUND". what is mean "Skipping link step. The project contains no linker script."? thank for concern
Sat Mar 15 2008, 05:34 pm
well the thing is.. MPLAB alone is just an editor so alone it wont work. You need an assembler or a compiler to be installed along with MPLAB and set the preferences in MPLAB to use it for assembling your codes.
Suggestion is download a MPASM from Microchip's website where you downloaded MPLAB.
Sat Mar 15 2008, 05:58 pm
thank, i got the MPASM compiler but there are still the same error pop out, here is the code that i get from the tutorial. i am trying to understanding the code and make it to achieve my objective.
;Tutorial 11
;Reading an analogue input, and displaying it on the LCD and RS232
	LIST	p=16F876, W=2, X=ON, R=DEC	;tell assembler what chip we are using
	include "P16F876.inc"			;include the defaults for the chip
	ERRORLEVEL	0,	-302		;suppress bank selection messages
	__CONFIG    0x393A			;sets the configuration settings (oscillator type etc.)
		cblock	0x20			;start of general purpose registers
			count
			count1
			counta
			countb
			LoX
			Bit_Cntr
			Timer_H
			Flags
			Flags2
			tmp1
			tmp2
			tmp3
			NumL
			NumH
			TenK
			Thou
			Hund
			Tens
			Ones
			templcd
			templcd2
			Point			;position of decimal point
		endc
LCD_PORT	Equ	PORTB
LCD_TRIS	Equ	TRISB
LCD_RS		Equ	0x04			;LCD handshake lines
LCD_RW		Equ	0x06
LCD_E		Equ	0x07
LEADZ         	Equ   	0x00   			;set to display leading zeros
LCD		Equ	0x01			;set to print to LCD
RS232		Equ	0x02			;set to print to RS232
;start of program
		ORG	0x0000
		NOP
		BCF	PCLATH,	3
		BCF	PCLATH,	4
		GOTO	Initialise
		ORG	0x0004
		RETURN
		ORG	0x0005
Initialise	clrf	count
		clrf	PORTA
		clrf	PORTB
		clrf	PORTC
		clrf	Flags
		BANKSEL ADCON1			;disable A2D
    		movlw   0x06
    		movwf   ADCON1
    		BANKSEL PORTA
						;variables for decimal numbers display
		bsf	Flags, LEADZ		;show leading zeros
		bsf	Flags, LCD		;set to print to LCD
		bsf	Flags, RS232		;and also to RS232
		movlw	0x02			;set decimal point position to two
		movwf	Point
SetPorts	bsf 	STATUS,		RP0	;select bank 1
		movlw	0x00			;make all LCD pins outputs
		movwf	LCD_TRIS
		bcf 	STATUS,		RP0	;select bank 0
		call	SER_INIT		;initialise serial port
		call	LCD_Init		;setup LCD module
		call	LCD_CurOff		;turn cursor off
		call	Init_ADC		;initialise analogue input
Main
		bcf	Flags,	RS232		;turn off RS232
		call	LCD_Line1		;set to first line
		call	String1			;display title string
		bsf	Flags,	RS232		;turn RS232 back on
		call	LCD_Line2
		call	Read_ADC		;read analogue input
		call	LCD_Decimal		;and display (in decimal)
		movlw	'V'
		call	LCD_Char		;display a 'V' on LCD only
		bcf	Flags,	LCD		;and turn off LCD
		movlw	0x0A
		call	LCD_Char		;display a LF
		movlw	0x0D
		call	LCD_Char		;display a CR
		bsf	Flags,	LCD		;turn LCD back on
		call	Delay100		;delay to give 10 readings per second
		goto	Main			;loop for ever
Init_ADC
; Set ADCON0
    		movlw   b'10000001'
    		movwf   ADCON0
; Set ADCON1
    		BANKSEL ADCON1
    		movlw   b'10000101'
    		movwf   ADCON1
    		BANKSEL ADCON0
		return
Read_ADC
    		bsf	ADCON0, GO_DONE		;initiate conversion
    		btfsc   ADCON0, GO_DONE
    		goto    $-1			;wait for ADC to finish
    		movf    ADRESH,W
    		andlw   0x03
    		movwf   NumH
    		BANKSEL ADRESL
    		movf    ADRESL,W
    		BANKSEL	ADRESH
		movwf	NumL			;return result in NumL and NumH
		return
;TABLES
HEX_Table  	addwf   PCL       , f
            	retlw   0x30
            	retlw   0x31
            	retlw   0x32
            	retlw   0x33
            	retlw   0x34
            	retlw   0x35
            	retlw   0x36
            	retlw   0x37
            	retlw   0x38
            	retlw   0x39
            	retlw   0x41
            	retlw   0x42
            	retlw   0x43
            	retlw   0x44
            	retlw   0x45
            	retlw   0x46
Xtext		addwf	PCL, f
		retlw	'T'
		retlw	'u'
		retlw	't'
		retlw	'o'
		retlw	'r'
		retlw	'i'
		retlw	'a'
		retlw	'l'
		retlw	' '
		retlw	'1'
		retlw	'1'
		retlw	'.'
		retlw	'4'
		retlw	0x00
;end of tables
String1		clrf	count			;set counter register to zero
Mess1		movf	count, w		;put counter value in W
		call	Xtext			;get a character from the text table
		xorlw	0x00			;is it a zero?
		btfsc	STATUS, Z
		retlw	0x00			;return when finished
		call	LCD_Char
		incf	count, f
		goto	Mess1
;USART Serial routines
SER_INIT
            	BSF     STATUS, RP0           ;select bank 1
     		MOVLW   d'129'                ;9600 baud @ 20 Mhz Fosc +0.16 err
     		MOVWF   SPBRG
     		MOVLW   b'00100100'           ;brgh = 1
     		MOVWF   TXSTA                 ;enable Async Transmission, set brgh
            	BCF     STATUS, RP0           ;select bank 0
     		MOVLW   b'10010000'
     		MOVWF   RCSTA                 ;enable Async Reception
            	RETURN
XMIT_RS232  	btfss   PIR1,	TXIF 	      ;xmit buffer empty?
     		GOTO	XMIT_RS232            ;no, wait
     		MOVWF   TXREG		      ;now send
                RETURN
Rcv_RS232   	BTFSS   PIR1,	RCIF 	      ; check for received data
     		GOTO    Rcv_RS232
                MOVF    RCREG,	W
                RETURN
;End of serial routines
;LCD routines
;Initialise LCD
LCD_Init	call 	LCD_Busy		;wait for LCD to settle
		movlw	0x20			;Set 4 bit mode
		call	LCD_Cmd
		movlw	0x28			;Set display shift
		call	LCD_Cmd
		movlw	0x06			;Set display character mode
		call	LCD_Cmd
		movlw	0x0c			;Set display on/off and cursor command
		call	LCD_Cmd			;Set cursor off
		call	LCD_Clr			;clear display
		retlw	0x00
; command set routine
LCD_Cmd		movwf	templcd
		swapf	templcd,	w	;send upper nibble
		andlw	0x0f			;clear upper 4 bits of W
		movwf	LCD_PORT
		bcf	LCD_PORT, LCD_RS	;RS line to 1
		call	Pulse_e			;Pulse the E line high
		movf	templcd,	w	;send lower nibble
		movwf	LCD_PORT
		call 	LCD_Busy
		retlw	0x00
LCD_CharD	addlw	0x30			;add 0x30 to convert to ASCII
LCD_Char	btfsc	Flags, RS232
		call	XMIT_RS232		;do RS232 if flag set
		btfss	Flags, LCD
		return				;return if LCD not set
		movwf	templcd
		movwf	LCD_PORT
		bsf	LCD_PORT, LCD_RS	;RS line to 1
		movwf	LCD_PORT
		call 	LCD_Busy
		retlw	0x00
LCD_Line1	movlw	0x80			;move to 1st row, first column
		call	LCD_Cmd
		retlw	0x00
LCD_Line2	movlw	0xc0			;move to 2nd row, first column
		call	LCD_Cmd
		retlw	0x00
LCD_Line1W	addlw	0x80			;move to 1st row, column W
		call	LCD_Cmd
		retlw	0x00
LCD_Line2W	addlw	0xc0			;move to 2nd row, column W
		call	LCD_Cmd
		retlw	0x00
LCD_CurOn	movlw	0x0d			;Set display on/off and cursor command
		call	LCD_Cmd
		retlw	0x00
LCD_CurOff	movlw	0x0c			;Set display on/off and cursor command
		call	LCD_Cmd
		retlw	0x00
LCD_Clr		movlw	0x01			;Clear display
		call	LCD_Cmd
		retlw	0x00
LCD_HEX		movwf	tmp1
		swapf	tmp1,	w
		andlw	0x0f
		call	HEX_Table
		call	LCD_Char
		movf	tmp1, w
		andlw	0x0f
		call	HEX_Table
		call	LCD_Char
		retlw	0x00
Pulse_e		bsf	LCD_PORT, LCD_E
		nop
		bcf	LCD_PORT, LCD_E
		retlw	0x00
LCD_Busy
		bsf	STATUS,	RP0		;set bank 1
		movlw	0x0f			;set Port for input
		movwf	LCD_TRIS
		bcf	STATUS,	RP0		;set bank 0
		bcf	LCD_PORT, LCD_RS	;set LCD for command mode
		bsf	LCD_PORT, LCD_RW	;setup to read busy flag
		bsf	LCD_PORT, LCD_E
		swapf	LCD_PORT, w		;read upper nibble (busy flag)
		bcf	LCD_PORT, LCD_E
		movwf	templcd2
		bsf	LCD_PORT, LCD_E		;dummy read of lower nibble
		bcf	LCD_PORT, LCD_E
		btfsc	templcd2, 7		;check busy flag, high = busy
		goto	LCD_Busy		;if busy check again
		bcf	LCD_PORT, LCD_RW
		movlw	0x00			;set Port for output
		movwf	LCD_TRIS
		return
LCD_Decimal
		call    Convert
		btfsc   Flags, LEADZ
		goto    LCD_TENK
		movf    TenK, w
		btfss   STATUS, Z
		goto    LCD_TENK
		movf    Thou, w
		btfss   STATUS, Z
		goto    LCD_THOU
		movf    Hund, w
		btfss   STATUS, Z
		goto    LCD_HUND
		movf    Tens, w
		btfss   STATUS, Z
		goto    LCD_TENS
		goto    LCD_ONES
LCD_TENK
		movlw	0x05			;test if decimal point 5
		subwf   Point, w
		btfss   STATUS    , Z
		goto	NO_DP5
		movlw	'.'
		call	LCD_Char		;display decimal point
NO_DP5		movf    TenK, w
		call    LCD_CharD
		movlw	0x04			;test if decimal point 4
		subwf   Point, w
		btfss   STATUS    , Z
		goto	LCD_THOU
		movlw	'.'
LCD_THOU
		movf    Thou, w
		call    LCD_CharD
		movlw	0x03			;test if decimal point 3
		subwf   Point, w
		btfss   STATUS    , Z
		goto	LCD_HUND
		movlw	'.'
LCD_HUND
		movf    Hund, w
		call    LCD_CharD
		movlw	0x02			;test if decimal point 2
		subwf   Point, w
		btfss   STATUS    , Z
		goto	LCD_TENS
		movlw	'.'
LCD_TENS
		movf    Tens, w
		call    LCD_CharD
		movlw	0x01			;test if decimal point 1
		subwf   Point, w
		btfss   STATUS    , Z
		goto	LCD_ONES
		movlw	'.'
LCD_ONES
		movf     Ones, w
		call     LCD_CharD
		return
;end of LCD routines
;Delay routines
Delay255	movlw	0xff		;delay 255 mS
		goto	d0
Delay100	movlw	d'100'		;delay 100mS
		goto	d0
Delay50		movlw	d'50'		;delay 50mS
		goto	d0
Delay20		movlw	d'20'		;delay 20mS
		goto	d0
Delay5		movlw	0x05		;delay 5.000 ms (20 MHz clock)
d0		movwf	count1
d1		movlw	0xE7
		movwf	counta
		movlw	0x04
		movwf	countb
Delay_0		decfsz	counta, f
		goto	$+2
		decfsz	countb, f
		goto	Delay_0
		decfsz	count1	,f
		goto	d1
		retlw	0x00
;end of Delay routines
;This routine downloaded from http://www.piclist.com
Convert:                        ; Takes number in NumH:NumL
                                ; Returns decimal in
                                ; TenK:Thou:Hund:Tens:Ones
        swapf   NumH, w
	iorlw	B'11110000'
        movwf   Thou
        addwf   Thou,f
        addlw   0XE2
        movwf   Hund
        addlw   0X32
        movwf   Ones
        movf    NumH,w
        andlw   0X0F
        addwf   Hund,f
        addwf   Hund,f
        addwf   Ones,f
        addlw   0XE9
        movwf   Tens
        addwf   Tens,f
        addwf   Tens,f
        swapf   NumL,w
        andlw   0X0F
        addwf   Tens,f
        addwf   Ones,f
        rlf     Tens,f
        rlf     Ones,f
        comf    Ones,f
        rlf     Ones,f
        movf    NumL,w
        andlw   0X0F
        addwf   Ones,f
        rlf     Thou,f
        movlw   0X07
        movwf   TenK
                    ; At this point, the original number is
                    ; equal to
                    ; TenK*10000+Thou*1000+Hund*100+Tens*10+Ones
                    ; if those entities are regarded as two's
                    ; complement binary.  To be precise, all of
                    ; them are negative except TenK.  Now the number
                    ; needs to be normalized, but this can all be
                    ; done with simple byte arithmetic.
        movlw   0X0A                             ; Ten
Lb1:
        addwf   Ones,f
        decf    Tens,f
        btfss   3,0
        goto   Lb1
Lb2:
        addwf   Tens,f
        decf    Hund,f
        btfss   3,0
        goto   Lb2
Lb3:
        addwf   Hund,f
        decf    Thou,f
        btfss   3,0
        goto   Lb3
Lb4:
        addwf   Thou,f
        decf    TenK,f
        btfss   3,0
        goto   Lb4
        retlw	0x00
		end
Sat Mar 15 2008, 06:01 pm
you dont need to download MPASM it comes integrated with MPLAB...
i beleive u have not included the 16fxx.lkr kinda linker file in your project so is the error..
Sat Mar 15 2008, 06:03 pm
thank, where the 16fxx.lkr should be?
Sat Mar 15 2008, 06:08 pm
you said you are trying serial port.. so why this LCD coming?
Sat Mar 15 2008, 06:21 pm
the linker file should be automatically fetched sill check if u made the project right atke a look at how it shud be done
Sat Mar 15 2008, 06:23 pm
thank :-) this the tutorial is about below. Is it ok, if i want to remove all the LCD output? before i remove it, i hope this code could run and do it step by step.
This time we add an extra board, the RS232 Board. The program is essentially Tutorial 11.3, but this time we add a serial output routine to send the data via RS232 to a PC. For the RS232 output we don't send the 'V' at the end, but we do send CR/LF in order to display each reading on a separate line. I've implemented this by modifying the LCD_Char routine and adding a couple of Flags - LCD and RS232 - by setting these flags ON or OFF we can print to either the LCD, the RS232 output, both, or neither.
Sat Mar 15 2008, 06:36 pm
if you have LCD on board then try it.. and test it.
Otherwise you can just take out the initialization, sending and receiving part of serial from the tutorial.
Clydehet
Wed May 01 2024, 06:44 pm
Davidoried
Wed May 01 2024, 06:11 pm
KevinTab
Sun Apr 28 2024, 05:35 am
Tumergix
Sun Apr 28 2024, 12:59 am
StevenDrulk
Sat Apr 27 2024, 08:47 pm
StephenHauct
Sat Apr 27 2024, 09:38 am
Adamsaf
Sat Apr 27 2024, 07:12 am
