8051 based temperature controlled fan
Wed Sep 05 2007, 12:02 am
ok.. now i got your schematic.. now explain me.. how you want your circuit to be operated.. i mean function of the parts. like what does switches do.. what is the use of display..
what is it going to display.. and how you what your fan to be controlled.. i just want to know a basic idea
Wed Sep 05 2007, 01:12 pm
coz tis is a group assignment, i m jz in charge of the part of the fan. wat i gonna do is to make the fan spin at different speed at different temperature. as my lecturer told me, to make tis simpler, we divide it into 3 parts which is to write the code for a slow speed fan, fast speed fan n to stop the fan. tis is the basic idea for me of the fan part. thx a lot, apprecated..
Wed Sep 05 2007, 08:59 pm
simulator will not give you answers you need
try running on the hardware..
Wed Sep 05 2007, 09:01 pm
icic. i will try it soon. coz i m still constructing the circuit. btw, the code i used is to control the fan in auto or in manual? coz in my assignment, i gotta do a manually n automatically control fan.
Thu Sep 06 2007, 08:54 am
ajay, i hav gotta ask about something related to the timer mode. can i change 1 of the code from MOV TMOD, #02H to MOV THO, R7?? by the way, can u briefly tell me wat code can i write to actually change the value of R7 in order to change the speed of the fan automatically? and also wat is a debouncing mean?? i need to use tis to control the fan by pressing button.
Thu Sep 06 2007, 01:27 pm
debouncing is related to keys not to fan control.. when you take your finger off the switch or say when you release the switch its called debouncing..
for automatic.. you can have some set of values.. like for temp range 10°-15° value of R7 is 15
for 15°-20° value of R7 is 30
and so on..
so when your ADC reads temperature in between any of the range it will automatically load the new value in R7 and hence speed will be controlled automatically.
and so on..
joshua like this.
