Discussion in "New Ideas regarding projects" started by    jeswanthmg    Jan 3, 2011.
Mon Jan 03 2011, 02:03 pm
Hi guys i am planning to do mini cnc machine to make pcbs i have got all the materials including 3x10kg stepper motors (Bi-polar) i am using SMPS power supply from meanwell.
I am using K-Cam software as interpreter
however i am making my own driver hardware if you guys have or known about some good high current driver circuits for bi-polar stepper motor plz post it.
Mon Jan 03 2011, 03:49 pm
hi jeswanthmg
good idea
what is the current of stepper motors
some circuits for dc motors r on this link
these r for dc motors but can be used for stepper if current limits meets
http://www.ikalogic.com/cat_motor_control.php
Mon Jan 03 2011, 06:07 pm
Hi majoka that link has no stepper motor driver but look at this circuit its cool its what exactly i wanted
i will test an construct 3 of this circuit for each axis and through parallel port i will configure k-cam software to send the pulses according to pcb layout.
hi majoka one more thing do you have any idea on PCB to G-Code converter software it would be of great help.
[ Edited Mon Jan 03 2011, 06:38 pm ]
Tue Jan 04 2011, 10:14 am
Hello jeswanthmg...
for hardware design of machine see this site this will help you...
CNC on a Budget
you will use Mach 3???
Download Mach 3 here
and to generate G.Code you can use CopperCAM.......
first generate CAM file with any PCB designing software and then generate G.Code of it using CopperCAM.... see this link for more help..
Generating G.Code from CAM file
[ Edited Tue Jan 04 2011, 10:16 am ]
 jeswanthmg like this.
Tue Jan 04 2011, 10:28 am
wow guys that links really helped me thanks a lot the best was GENERATING GCODE from CAM FILE.
@ coolmirza
have you done any project regarding cnc are you mechanical engg!ow
[ Edited Tue Jan 04 2011, 10:33 am ]
 coolmirza143 like this.
Tue Jan 04 2011, 10:56 am
@ coolmirza
jeswanthmg
no dear i am Telecomm Engineer not mechanical but i did some work with CNC using Match 3 to write G.Code....
never used it for PCB makig i used this for some mechanical work that was requirment of a university to sattle some small CNC Machine for their mechanical lab work.....
people are using CNC for pcb manufacturing i see some home made machines that are in use.......
you can make your own see the link that i provided in upper post that was CNC Budget....
best of luck...
Tue Jan 04 2011, 04:08 pm
thanks i have planned all things. infact i have brought most of the components i am going to use kcam software later i will use mach 3 only thing i needed was pcb layout to gcode converter, now i got it thanks again i will work slowly on this project step by step
Tue Jan 04 2011, 09:38 pm
hi jeswanthmg
update about ur work and experience here
Tue Jan 04 2011, 11:09 pm
@majoka
yeah i am going to upload the photos soon i am very exited about this project
JamesroW
Mon May 06 2024, 09:37 am
Chrispes
Mon May 06 2024, 07:34 am
ArktiTic
Sun May 05 2024, 07:06 pm
CesslasyNear
Sun May 05 2024, 02:58 pm
chimichmedic1204
Sun May 05 2024, 11:06 am
Jamiegob
Sun May 05 2024, 10:11 am
Gregoryjed
Sun May 05 2024, 10:02 am
Mariocax
Sun May 05 2024, 08:51 am
