Discussion in "8051 Discussion Forum" started by    kirangowle    Jan 11, 2011.
Wed Jan 12 2011, 05:02 pm
Hi,
See the attachment
The freq of AC is 50Hz so T=1/50=20ms
T for per cycle will be =20ms/2=10ms.
From as per the calculation i need to generate the gate pulse at the interval of 10ms.
From the fig, Zero cross ref signal is of 10msecs which will be given to controller(INT0).
Now how to read this signal and generate the short pulse at the interval of 10ms.
Wed Jan 12 2011, 07:45 pm
are you sure your zero cross detector o/p is like that? can you post ZC detector circuit?
you can poll that pin state using a timer.. thats possible coz as per your attachment, ZC o/p state changes whenever your cycle changes..
as you are already connecting ZC o/p to interrupt pin. so whenever interrupt comes wait for some time and give a pulse. Only thing is the -ve AC cycle will not come into picture. this will not give you good results but will work.
Thu Jan 13 2011, 10:05 am
Hi Ajay,
I have not developed zero cross detector ckt. I m searching for that ckt whose output of zero cross detector is as above fig. Now i m trying on proteus to the simulation as above.
Do u have working circuit for zero cross detector?
Thu Jan 13 2011, 11:03 am
kirangowle
hello kiran!!
see the circuit below..... it will generate a pulse at every zero crossing....
 kirangowle like this.
Thu Jan 13 2011, 11:13 am
see this video for more help... replace L1 with your fan in following circuit shown in video....
Thu Jan 13 2011, 12:54 pm
Hi Mirza,
Thanks dude your Zero crossing ckt is working fine.
In Hardware can i give directly 230V? r else i have to step down it.
Now i have to connect output of this ckt to 8051 interrupt pin.
Thu Jan 13 2011, 02:59 pm
no you have to use step down 220v ac.... never apply input directly its better to use step down transformer for it...... you can reduce input voltages by resistors like 120k in series with 220v but it will be dangerous not safe!! so i will suggest you to use transformer and then apply input to this circuit....
Thu Jan 13 2011, 05:05 pm
Hi,
I have written code for external interrupt. its a edge triggered interrupt.
#include<reg51.h>
sbit pulse=P1^1;
sbit led=P1^0;
void delay(unsigned int i);
unsigned int i;
void interrupt0(void) interrupt 0
	delay(0);
        pulse=1;	  // A short pulse making high to low
	delay(0);
	pulse=0;
	led=1;
	delay(10);
        unsigned int k, l;
        for(k=0;k<i;k++)
                for(l=0;l<1000;l++);
void main(void)           //main function
IT0=1;       //int 0 is edge triggered
IE=0x83;   //enable all ints along with tr0(not used here actually) intr and int0
	led=0;
But the above code is not working
The input is square wave of 50hz freq.
Fri Jan 14 2011, 09:27 pm
well i am again doubtful.. about your zerocross output... i think you should give a check again... built it on hardware and see the output.
for safety you must use a transformer, but you can still make transformer-less zero cross detector. dont ask me how select the complete word "zerocross detector" and click learn more.
Wed Jan 19 2011, 08:47 pm
Hi,
I am wondering if I am using 120vac instead of 220vac. How to I choose the TRIAC, what model I should use?
thanks.
EriksaLaf
Mon Jun 17 2024, 03:13 pm
Anthonyjinee
Mon Jun 17 2024, 06:23 am
Danieldus
Sun Jun 16 2024, 09:44 pm
Richardrig
Sun Jun 16 2024, 03:05 pm
StevenBrere
Sun Jun 16 2024, 04:23 am
Meganmiz
Sat Jun 15 2024, 09:17 pm
RobertDremn
Sat Jun 15 2024, 02:18 pm
Eugenearilk
Fri Jun 14 2024, 03:16 pm
