Urgent Help Needed for Bluetooth Controlled Robot
Fri Apr 11 2014, 11:43 am
I think you can use HC-07 as the whole HC-xx series is similar with minor feature and configuration differences. but on the basic side they are all same. I could not find any datasheet or information regarding this module however there is HC-06 is also there if HC-05 is not available for you.
Fri Apr 11 2014, 03:57 pm
Please suggest me a site I should buy the HC-05 bluetooth module from...(with link please)
Sun Apr 13 2014, 12:14 am
There are many websites that sell HC-05/06 modules just try a google search. Rydolabz is one... There are more just don't remember names.
And for voltage regulator. You can look into local market as I am not sure about prices. One of the 3.3v low dropout regulator is LM3940 with 1A of current.
Tue Apr 22 2014, 07:16 am
I bought this http://www.ebay.in/itm/161258846817?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 for programming my uc.
I need step by step procedure for operating this...pls
Wed Apr 23 2014, 11:32 am
There is an "Instruction manual for Connecting Programmer To Microcontrollers" also check the official USBasp Programmer website for more information and softwares available for flashing: http://www.fischl.de/usbasp/
Sat Apr 26 2014, 11:35 pm
For the 3.3V supply for HC-05, I've bought L7HL33 component.
Can I use L7HL33 for giving 3.3v supply for HC-05?
Mon Apr 28 2014, 11:33 am
Its hard to say for L7HL33 as I am unable to find datasheet for the same. make sure you keep the voltage divider when connecting controller with HC-05.
Tue Apr 29 2014, 12:17 pm
