Need Serious Help
Thu Jan 22 2009, 06:28 AM
sorry to trouble you guys again. I wan to know how to use hyperterminal to send data through serial port. Because I want to test whether my serial communcation coding for microcontroller works or not.
Thanks!
Thanks!
Thu Jan 22 2009, 07:59 PM
go to Start->all programs-> Accessories -> communication -> hyper terminal
then follow instructions to create new connection, use COM port when selecting connection. use baudrate settings on default of use as follows:
Baud: 9600
Data: 8-bit
Parity: none
Stop Bit: 1
if you feel any problem then please ask.
Baud: 9600
Data: 8-bit
Parity: none
Stop Bit: 1
Fri Jan 23 2009, 12:05 AM
ya i did that and i also go to file > properties > setting tab > ASCII setup
Then i checked on echo type characters locally.
Like that when i type an "a", then i show 2 "a". Like that means ok right?
Then if I want to pass value, I type on the hyperterminal or must use file to send?
Thanks!
Thanks!
Fri Jan 23 2009, 09:19 AM
oo ok thx! guys can help me check whether my C coding is correct or not, just check my serial communication code. THANKS! I LOVE U GUYS!
Fri Jan 23 2009, 07:39 PM
its better if you can check it yourself first and if you are getting errors then tell me. also if your program is behaving unexpectedly. Still if you want us to check then paste the code here.
Sat Jan 24 2009, 01:43 AM
ok i will give the result on this coming wednesday. Oh ya if I use hyperterminal to send a text file, will the microcontroller read the file? or how will it react?
Sat Jan 24 2009, 07:46 PM
no controller cannot read file directly, sending a file follows a protocol ex. Xmodem, which controller need to take care. if you can implement that protocol on controller then YES you can read file
Tue Jan 27 2009, 08:27 PM
you can try google.. here are some links i found good.
http://www.programmersheaven.com/download/2167/download.aspx
http://en.wikipedia.org/wiki/XMODEM
